hello all , i was wondering if you guys could help me out a bit on something.
I am playing firefall and it frequently has fps lag, so my question is, do i need to upgrade my cpu or gpu?
cpu: dualcore Intel e2180
gpu: nVidia geforce 9600gt with 512mb ram.
also i have 4GB ddr3 ram
So like i said, does my cpu or gpu make the game lag ? ( on minimum settings) especially when there are 2 or more players and alot of action is going on...
which do you recommend ( keep in mind i need it only for gaming, and yes i know my configuration is very weak but it is what it is,just looking to make it sufficient enough so i can play some games normaly)
Thanks to all that can help me :))
