Is Fractal Design Define Nano S compatible with my m-ATX Form Factor motherboard?
Hello I have this motherboard:
MSI B450M PRO-VDH MAX with this dimensions:
Dimensions
9.6 in. x 9.6 in. (24.4 cm x 24.4 cm)
m-ATX Form Factor
I want to buy the Define nano s case but I do not know if it will be compatible. On their site they say
Motherboard compatibility
ITX, Mini DTX
Your motherboard is µATX
The Define Nano S supports up to mDTX
Here is a helpful schematic yanked from Wikipedia:
So, no. You’d need to buy an ITX motherboard for that case. Recommend either this:
Or getting the Define 7 Mini over the Define 7 Nano:
I was about to hit enter to reply.
What he said.
Thank you guys for your helpful answers.
FD Define-C / Define Mini-C, be the model tier you’d be shaking down
This topic was automatically closed after 273 days. New replies are no longer allowed.
