I was wondering if I can build a dual system unit (one with an itx for 2nd system) with power redundancy if i connect the Phanteks revolt X on the 2nd power supply input of the Phanteks Revolt Pro?
Phanteks Revolt Pro (inputs)
So 1st system will be connected from the Revolt Pro’s outputs and the 2nd system will be connected on the Revolt X’s 2nd system outputs.
I guess you could. But, just to be sure, I’d ask to Phanteks if it’s possible to daisy chain a Revolt X and a Revolt Pro.
Doing so just one system will have redundancy in case of a PSU fail.
