CAM is an unmitigated DISASTER - get a H100 or H150 if you want liquid. Get a D-15 or dark rock pro if you want air.
why do you think im not hitting my boost speeds?
Arenāt they exactly the same Asetek AIO?
It should be, but it seems like we are running on the same issue, you and i.
your not getting boost speeds??
Not max boost, no, Iām getting around 4075mhz on full load and around 78Ā°c of temperature, max boost i got was 4225mhz on some games.
Mine is the 3600x.
our temps are good!!
For a space heater, perhaps lol
the max temps for my cpu is 95c or 100c so i think 78c under a stress test is good.
But its on an H100i, isnāt it? Perhaps it would be alright for the stock cooler, but it seems high for a medium sized AIO.
Mine is almost the same as yours, a 280mm Thermaltake Water 3.0.
yours is bigger, mine is a 240mm rad. so thats also why i think my temps seem to be decent.
your rad is bigger so yes maybe the temps are a little high for your cpu. maybe.
H100 is a different cold plate housing. They have a history of leaks.
Hmm, interesting.
Do you know what is my Thermaltake Water 3.0 model more similar to, the Kraken or the H100i?
IDK. Asutek has a lot of models but they arenāt the only generic either. The only reason I know anything about the H100 or the Kraken is for water cooling my G5.
