Is a 550w corsair power supply enough to power all this?
Power supply: Corsair 550W TX550M Enthusiast Series Modular
Fractal Design Arc MiniTower
CoolerMaster Hyper 212 EVO CPU Cooling
Samsung SH-224BB SATA DVD-RW Burner
Corsair 60GB SSD Force3 (SATA-600, 2.5")
Re-use wd 500gb
Corsair 8GB PC3-12800 XMS3 DDR3 SDRAM (2x 4GB, 1600MHz)
ASRock Z77 Pro4-M (Socket 1155)
Intel Core i5 3570K (Socket 1155, Boxed)
Gigabyte ATI Radeon HD7870 2GB DDR5 Ultra Durable (PCI-e)
Please use enter!
It's not that hard!
Anyway, i believe that is enough for that system. However i would go with 600w or 650w in case you're going to do future upgrades.
Sorry:
Re-use wd 500gb
ASRock Z77 Pro4-M (Socket 1155) Intel Core i5 3570K (Socket 1155, Boxed)
Henkjan1998 here is a really good power supply calculator you can use to get a basic gauge of how many watts power supply you need: http://www.extreme.outervision.com/psucalculatorlite.jsp
Here is a overclocked 3960x with a 7870 :http://www.anandtech.com/show/5767/capsule-review-sapphires-radeon-hd-7870-overclock-edition/4
As you can see it pulls 331watts from the wall under full tilt, the TX550 will do the job fine.
Yep - 550w would be fine for that but if your thinking about adding another 7870 in the future I would get a higher wattage
