Has anyone here used an IP camera tester before or maybe recommend one? I am gearing up to do a bunch of camera installs across several sites and was thinking about getting something like this:
Seems like it could be a little more convenient than just using my laptop for everything but just wanted to see if anyone thought they were worth it.
The laptop is much more versatile of a tool and likely you will need one regardless. If you haven’t got one already, the tool to look for would be a good network cable tester to make sure runs are terminated correctly.
