InWin 301
I'm in love. Not sure if it'll fit a custom loop and full length graphics card though, hmmm.
it's really tight in that case, maybe slim fans or radiator will help.
Also depends on the GPU, I've opted for the larger 303, I really like the aesthetic of the 301/303.
I've got a MSI gtx1080 gaming x, they used a mini card at CES with a custom loop which makes me think it won't fit. . He made a mistake with that review, the bottom is meant to be the main intake.
I'm going to get it when it's released in the uk (May I think). That and the 3[3 are so pretty imo.
If I can't fit a custom loop in there EKWB are releasing new all in one watercoolers soon as well, they should be good.
It is an ugly, plain box. LOL!
I disagree but it's perfectly acceptable for you to think that. Won't change my mind about getting it that's for sure.
it looks like one of those 1980s stereo cabinets that has the stacked componenets in it.
One of their (EKWB) AIOs might do the trick as the pump is on the rad and is expandable too.
It's $69 and it comes without any fans. To top it off there's very little room for airflow. It's a badly designed case. For mATX I'd just get Fractal Design Arc Mini R2.
Cheap and I'd change the fans anyway, I'm sure the airflow is better if it's built correctly :laughing:.
I'd vomit every time I looked at it.
Fake! Xbox 360s weren't around in the 80s!
Always been a fan of InWin's designs. Now I understand they're not the most practical cases out there. But people who complain about that don't realize that's not the point. An InWin case is a work of art, a stylish display cabinet for your components. Personally I think it achieves that goal quite well.
All my components are black /red too. I think it'll look amazing. Really hope ekwb do a great job with their new aio,that'll make the whole build perfect for me.
That throws a spanner in the works, trying to choose a case that balances aesthetics , size and watercooling support is driving me slightly crazy.
Here's your answer.
why....
Does those guys have a shitty attitude...
Yeah... I definitely don't regret unsubscribing their channel and ignoring their content...
