Seems like intels ultra aggressive power and thermal designs finally caught up with them in end/user visible way. Some proverbial bucket finally spilled, and end users notice. Wonder what combination of factors is it this time.
What surprises me it has not happened sooner, upper end i7s and i9 were truly insane in last few generation, and getting more insane.
There was a fellow here on the forums cluelessly asking why is he getting bad temperature and throttling on 14900KS:
- 24 core heterogeneous cpu
- up to 300-400W real world power draw (Cpu only !)
- thermal ceiling is reached immediately even with high end air cooler or custom hydro
=> these are not reasonably binned and configured platforms even in ideal environment and ideal platforms.
While KS is the extreme that proves the point, lower ones are off the hook either.
Way too much power running through too little area. Now if you activate XMP and incidentally overvolt IMC, magic smoke might happen soon. Add in mobo vendor insane hidden defaults for little bit more suprise and sprikle MultiCoreEnhancement on by default for shit and giggles.
I just cannot imagine how something like that, at near cutting edge litography nodes, can work long term or on sustained workload.
Also small tldr:
If cpu cannot reliably operate on advertised clocks on stock setting, then they are defective product , full stop. RMA aggressively and demand full refund. Throw motherboard in for good measure. Reason for malfunctions does not matter in the end, and motherboard is useless for defective cpu line.
Beancounter and managements are banking on there being confusion and will be hot potato throwing blame between MB and system integrator as long as necessary for easy legal return windows to run out.
EDIT2:
Its insane to know some people are running frankenmoster servers on this platform and actually using it for real world production. Game servers yes, but still production.
It doesn’t matter if you use W series chipset and supermicro boards, its still consumer platform with all the relevant corners cut at design phase.
There are enterprise grade hardware readily available that’s not that expensive and not that significantly slower. You have to spend money to make money.
Talk about self-inflicted wounds here.
EDIT3:
Wendell: … Not so fast there Chuckles!
That quote deserves to be stolen and broadly applied elsewhere, huehue
Sidenote - is the Steves comment about server providers loosing trust in intel due to this actually reasonable?
- this is contained to 13th and 14th generation consumer lineup, not xeon line
- absolute majority of actually used hardware in enteprise market is not affected or theoretically impacted at all
- hosting and supporting this kind of setup is niche market, no?
- we talking the chipzilla here, even if some smaller server hosters threatened to boycott them over this, what do they care? Few tens thousands of lost sales is drop in a bucket for them.
