Asrock x399 Tai Chi WiFi not working
I have windows 10 installed.
I never used wifi on desktop pc but now i need to use it.
When i unplug LAN cable i see this this icon on bottom left corner:
When i go to “Start” >> “Control Panel” >> “Network and Internet” >> “Network and Sharing Center” >> “Change advanced sharing settings” >> I have “Turn on network discovery” enabled.
As far as i know i should get available WiFi connections visible when i clikc on the WiFi icon on bottom right corner.
Tho i have not installed any special drivers or software regarding the MB.
AsRock WiFi connector utility is also installed and set to ON but issue remains.
ftp://asrock.cn/Manual/WiFi/X399%20Taichi.pdf
I dowloaded drivers from here
https://www.asrock.com/mb/AMD/X399 Taichi/index.asp#Download
Intel_WLAN(v19.60_0717)
