I’ve never used optane and my environment doesn’t ask for storage expansion (I’m barely using what I already have). I’d like to have some, but I’m not going to try find a use for them.
If I had the hardware to push it, I’d use them for ZFS metadata special device (mirror vdev) and write-cache (another mirror vdev) for a spinning rust pool. But I don’t (most of my hardware is low-power and little connectivity / expansion).
You see, that’s where I diverged from the norm and kinda went schizo. I’m using a combination of net-boot root-on-nfs and local boot off of microsd with root-on-tmpfs (to basically stop all writes to the sd - everything happens in RAM).
Call me crazy, but this way you can just use NFS for your os (and data) and have cheap redundancy and backup (I have a central NAS with SATA SSD mirror and I can back it up with zfs-send over to a spinning rust pool and to my other spinning rust backup server). Well, back when I built this setup, sata was still cheaper than nvme and optane drives weren’t nearly as affordable.
But the thing is, given the small sizes, I don’t see optane being much of a use, other than accelerating zfs hdd pools. I think that’s the ideal place for it. If I want to have a bunch of OS rootfs, I’d go for a larger (and slower) sata ssd pool (like I already have - if I were to build something today, I’d go full nvme if I had the money lmao, RIP whoever’s building PCs or buying SBCs in 2026).
A 2 or 4TB mirror vdev can handle the OS rootfs for a huge number of hosts and containers and even store some data that needs faster access times (idk, some small DB workloads - we’re talking homelab / homeprod here). All the additional data can go on the larger spinning rust (or in my case, my 8TB SSD stripped-mirror pool on my other NAS-hypervisor combo, before it goes to my HDD mirror NAS).
Justifying my own stuff.
My idea behind the small 2TB pool was to have a “bare-minimum” infrastructure running on it (VPN router VMs, DNS, DHCP, network ad-blocker, monitoring, home portal etc.) and have the beefier PCs do heavy duty stuff (heavy virtualization, like lab setup and testing, more intensive tasks like in-home vid streaming etc.).
That was for power constraints (I don’t like paying huge electric bills) and I took it way too far (I admit, but I’m not going back now). And after that, I kinda delayed and delayed, then I moved and I got to a pretty dusty place and I haven’t build a filtered environment for my PCs, so I avoided powering them on for quite a while now (to not have them ingest the nasty kind of dust from here).
With the weather getting warmer in the northern hemisphere, I can resume working on that and build an enclosure with some air-conditioner vent filters (the HEPA stuff), so I know my PCs won’t need tons of maintenance when running them constantly. I’ll basically be building a “mini-rack” (for lack of a better term) with a custom size (since I can’t use the network racks with the 16 x 20" filters and have enough space for everything else). And I need to attach my fused switch boxes on the outside and route the power cables in through some grommets. Yeah, as you might’ve guessed, I’m taking things too far… again.
