Intel Optane PMem NUMA Affinity Issue Leading to Performance Problems
TL;DR:
On my dual-socket server, Optane PMem (in App Direct mode) is assigned to separate, non-CPU proximity domains in the ACPI SRAT table (e.g., CPUs are domains 0/1, PMem is 2/3). This causes Linux (both old and new kernels) to fail in correctly identifying the PMem’s NUMA affinity. Performance tests show no NUMA effect—remote access is sometimes even faster than local. I suspect this is due to a BIOS HMAT policy, but I’m stuck on how to fix it.
Full Post:
Hello everyone,
I’ve run into a tricky PMem NUMA performance issue while setting up a server. After an in-depth investigation, I’ve hit a wall and would appreciate some advice.
Hardware and Configuration:
  • Server: A dual-socket server
  • CPU: 2 x Intel(R) Xeon(R) Gold 6330 CPU @ 2.00GHz (corresponding to NUMA nodes 0 and 1)
  • Memory: 8 x Intel Optane Persistent Memory 200 Series (PMem)
  • PMem Configuration:
    • Mode: App Direct
    • Interleaving: Intra-socket interleaving
    • Logical Devices: Presented to the OS as two block devices, /dev/pmem0 and /dev/pmem1, which are expected to be affiliated with NUMA nodes 0 and 1, respectively.
The Problem:
1. Incorrect NUMA Node Assignment:
  • On an older Linux kernel, the output of cat /sys/block/pmem0/device/numa_node was -1 .
  • After upgrading to Ubuntu 22.04 (with a newer kernel), the numa_node for both pmem0 and pmem1 shows 0 . I believe this is incorrect, as they can’t both belong to node 0. It seems to be a fallback default value.
2. Performance Tests Confirm the Issue:
My Investigation Steps:
1. Checked the ACPI SRAT Table: I believe the root cause lies within ACPI. The SRAT table shows:
  • The two CPU proximity domains are correctly identified as 0 and 1 .
  • However, the two PMem logical devices are assigned to new, separate proximity domains: 2 and 3 .
2. Enabled SNC (Sub-NUMA Clustering): I tried enabling SNC in the BIOS, which expanded the CPU NUMA domains to four (0, 1, 2, 3). In response, the PMem devices’ proximity domains simply shifted to 4 and 5 . This indicates a deliberate BIOS policy to always isolate PMem devices in their own domains.
3. My Hypothesis: I’ve learned this might be an advanced BIOS feature related to HMAT (Heterogeneous Memory Attribute Table) . This feature reports PMem as a separate “Memory-only” domain to provide finer-grained information about the memory hierarchy. However, I strongly suspect this is what’s preventing the Linux kernel from correctly associating the PMem devices with their physically adjacent CPU NUMA nodes.
My Dilemma and Questions:
I’m now at a crossroads. Either my BIOS is misconfigured, or my newer OS is missing a step needed to correctly interpret this advanced HMAT information.
  1. BIOS Level: What specific settings should I look for in the BIOS/UEFI to change this reporting behavior? For instance, is there a way to disable HMAT or force the PMem proximity domains to align with the CPU domains (e.g., pmem0 → domain 0, pmem1 → domain 1)?
  2. OS Level: On a modern system like Ubuntu 22.04, are there any specific kernel parameters or advanced ndctl commands that can be used to manually associate these detached NUMA domains?
  3. Other Possibilities: Have I overlooked any other potential avenues for investigation?
Thank you for any help or suggestions you can offer!
This sounds like something is assuming that the direct access memory will always be faster than any other memory type and so does not account for when the table is not sorted correctly. I’m not a bios programmer though so I could be wrong.
