Intel i915 sr-iov mode for Flex 170 + Proxmox PVE Kernel 6.5
Is this at all possible on the intel arc 310? I dont need a lot of power just run 2 windows vms with accelerated graphics.
if intel (develops & ) releases a working firmware, very possible. :wink:
I got it working on my Intel Nuc NUC13ANKi5. iGPU works in Proxmox, a Debian Guest and the docker containers in the Debian Guest.
I can’t post the commands here as it includes links … anyone interested pm me.
Should be able to post links now, if not let me know
Is your setup unique to SR-IOV? Or can older intel iGPUs achieve similar?
I am using 8th Gen intel / UHD 630, it seems you are dedicating that GPU to this one VM? Or have I misunderstood?
The Intel i5-1135G7 is Tiger Lake. I misspoke on my previous post.
Na you can go another Route for your IGPU
You can assign them with GVT-g and not sriov.
GVT-g Works from haswell and up to 10th gen afaik. In Unraid there is a Plugin to assign Parts of the GPU for acceleration to VM‘s
Ok thanks for pointing that out.
I’m using Proxmox. I’ll have to search for a guide on GVT-G.
I actually have an unraid server but I’m in progress of migrating all the services to Proxmox.
"The 11th Generation of Intel® Core Processors works with SR-IOV (Single Root IO Virtualization), that is a new virtualization feature supported in hardware starting from Intel® Iris® Xe and in some of our discrete cards.
Gen9 (i.e. Graphics powering 6th through 9th generation Intel processors) is the last generation of the software-based vGPU solution GVT-G (Intel® Graphics Virtualization Technology –g)."
https://www.intel.com/content/www/us/en/support/articles/000058558/graphics.html
Hey guys - I’ve worked through the guide on my MS-01 and have been able to activate SR-IOV for the iGPU in Proxmox. However, I’m struggling to enable the driver on an Ubuntu guest VM. I can see the passed-through iGPU on the guest, but I’m unsure how to install the driver and enable it - the guide on the strongtz/i915-sriov-dkms github page is very limited, and I think I’m missing some key details. Many of the guides online describe using a Windows guest, so I’m a bit stuck.
  • Does anyone have a guide to install/enable the strongtz/i915-sriov-dkms driver in Ubuntu?
  • Does the Kernel version in the guest need to match the proxmox host?
  • Does the Ubuntu guest kernel need to be downgraded from 6.8 (if so,how?), or are the issues with 6.8 just limited to proxmox?
Thanks all!
Hi @minez - you sound like you’re in a similar position to this thread - give it a read and see if that helps you out.
It specifically addresses iGPU vfio functions passed to a guest VM (in this case, for the purposes of hardware-accelerated transcoding in Jellyfin).
I915 SR-IOV on i9-13900H (Minisforum MS-01) Proxmox PVE Kernel 6.5 - Jellyfin Full Hardware Accelerated LXC
There was a PR merged by Intel to the backport/main repository, now with support for kernel version 6.8
Built the out-kernel-tree module on Proxmox 8.2.2 and Ubuntu 24.04 as client.
Hi,
Two days ago, I received a Flex 170 for testing. We’d like to use it in a productive environment for CAD (low budget, so NVIDIA is not an option).
I’m testing it on a Minisforum ar900i board with an i9-13900HX processor. However, I can’t get it running. I tried Kernel 6.5.13-6-pve and 6.8 as well.
My GRUB line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet intel_iommu=on iommu=pt i915.enable_guc=3 i915.max_vfs=7 i915.force_probe=56c0"
dmesg | grep -i i915 (The Intel Flex is the 3rd from below, ID 03:00.0
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.5.13-6-pve root=/dev/mapper/pve-root ro quiet intel_iommu=on iommu=pt i915.enable_guc=3 i915.max_vfs=7 i915.force_probe=56c0
[    0.118983] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.5.13-6-pve root=/dev/mapper/pve-root ro quiet intel_iommu=on iommu=pt i915.enable_guc=3 i915.max_vfs=7 i915.force_probe=56c0
[    3.137827] i915: unknown parameter 'max_vfs' ignored
[    3.139086] i915 0000:00:02.0: [drm] VT-d active for gfx access
[    3.139105] i915 0000:00:02.0: vgaarb: deactivate vga console
[    3.139143] i915 0000:00:02.0: [drm] Using Transparent Hugepages
[    3.139785] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    3.140400] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
[    3.142924] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/adls_dmc_ver2_01.bin (v2.1)
[    3.146012] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/tgl_guc_70.bin version 70.29.2
[    3.146015] i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
[    3.148253] i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
[    3.148579] i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
[    3.148580] i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
[    3.149035] i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
[    3.149506] mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
[    3.149636] i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
[    3.184808] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[    3.186250] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    3.186870] i915 0000:03:00.0: Force probing unsupported Device ID 56c0, tainting kernel
[    3.186894] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[    3.187540] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
I always encounter the problem that the Flex 170 drivers are not supported by the kernel, and forcing them doesn’t help. Could you provide details on which drivers you used exactly? I have tried quite a few, but none of them worked for me.
Passing Through the IGPU however, worked without any problems.
Did you try the i915 driver from the guide at the top of this post? (I’ve not been following to see if it’s in this Proxmox kernel.)
K3n.
It appears that the problem lies with the SR-IOV implementation on my motherboard not functioning properly. Initially, after installing Flex, the system failed to boot. During the early stages of debugging, I reset my motherboard settings and accidentally forgot to reactivate SR-IOV.
Once I noticed this, I attempted to reactivate SR-IOV, but the hardware wouldn’t boot at all—not even into the BIOS. However, when I unplug the Flex card, everything works fine, and SR-IOV functions correctly with my Nvidia Tesla M10.
I have tried various BIOS settings to resolve the issue, but I’ve had no success in getting it to work.
