Hello!
I have a new Threadripper build on Ubuntu 18.10 with 2950x and Gigabyte Designare x399 board. The LAN adapters are Intel i211AT. Out of the box, I see that I am limited to 100 Mb/s.
dmesg:
[ 1.305117] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.305559] igb: Copyright © 2007-2014 Intel Corporation.
[ 1.536886] igb 0000:04:00.0: added PHC on eth0
[ 1.537354] igb 0000:04:00.0: Intel® Gigabit Ethernet Network Connection
[ 1.537826] igb 0000:04:00.0: eth0: (PCIe:2.5Gb/s:Width x1) e0:d5:5e:ad:08:47
[ 1.538289] igb 0000:04:00.0: eth0: PBA No: FFFFFF-0FF
[ 1.538749] igb 0000:04:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx queue(s)
[ 1.769088] igb 0000:06:00.0: added PHC on eth1
[ 1.769747] igb 0000:06:00.0: Intel® Gigabit Ethernet Network Connection
[ 1.770408] igb 0000:06:00.0: eth1: (PCIe:2.5Gb/s:Width x1) e0:d5:5e:ad:08:49
[ 1.771018] igb 0000:06:00.0: eth1: PBA No: FFFFFF-0FF
[ 1.771474] igb 0000:06:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx queue(s)
[ 1.773564] igb 0000:06:00.0 enp6s0: renamed from eth1
[ 1.808173] igb 0000:04:00.0 enp4s0: renamed from eth0
[ 10.784580] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 12.948103] igb 0000:04:00.0: exceed max 2 second
[ 12.948424] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Down
[ 14.704581] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 16.864100] igb 0000:04:00.0: exceed max 2 second
[ 16.864416] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Down
[ 18.612575] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 20.772116] igb 0000:04:00.0: exceed max 2 second
[ 20.772432] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Down
[ 21.368591] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
I installed the driver for the LAN adapters.
Same result as before.
If I try to force the 1000 Mb/s speed wtih ethtool (ethtool -s enp4s0 speed 1000 duplex full):
dmesg:
[ 1245.188629] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 1246.327991] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Down
[ 1249.064659] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 1250.211990] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Down
[ 1252.920676] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 1254.064023] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Down
[ 1259.400706] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[ 1260.556056] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Down
It just keeps going up/down indefinitely.
