I’m trying to get pcie passthrough with Intel b50 on MPG X570 GAMING PLUS moba under Proxmox 9… and it’s super weird. Basically each time I do anything related to vfio modules the gpu disappears, no longer shows with lspci. To make it show again I have to physically power off the machine.
Any ideas what might be going on?
The steps I have taken to get pcie passthrough working:
Made sure IOMMU works. It has turned out with 7.0.6-2-pve I didn’t have to add amd_iommu=on, as it was already working
I’ve added conf entry for vfio, vfio_iommu_type1, vfio_pci in /etc/modules.d.
Blacklisted xe by creating entry in /etc/modprobe.d/
Added options vfio-pci ids=<IDs> disable_vga=1 in /etc/modprobe.d/vfio.conf - in my case the id was 8086:e212
Did update-initramfs -u -k all and rebooted
… and basically that’s when “fun” started. The device no longer showed with lspci . It’s like anything that was on 12:00.0 was gone. Further reboots did not help. But complete shutdown (with power completely disconnected) did.
Sadly the B50 still has tendency to disappear - and any suggestions are greatly appreciated.
Some info on my system:
lspci | grep Intel
10:00.0 PCI bridge: Intel Corporation Device e2ff (rev 01)
11:01.0 PCI bridge: Intel Corporation Device e2f0
11:02.0 PCI bridge: Intel Corporation Device e2f1
12:00.0 VGA compatible controller: Intel Corporation Battlemage G21 [Intel Graphics]
13:00.0 Audio device: Intel Corporation Device e2f7
lspci -n -s 12:00.0 -v
12:00.0 0300: 8086:e212 (prog-if 00 [VGA controller])
Subsystem: 8086:1114
Flags: bus master, fast devsel, latency 0, IOMMU group 12
Memory at fb000000 (64-bit, non-prefetchable) [size=16M]
Memory at 7800000000 (64-bit, prefetchable) [size=16G]
Expansion ROM at fc000000 [disabled] [size=2M]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Endpoint, IntMsgNum 0
Capabilities: [ac] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [d0] Power Management version 3
Capabilities: [100] Alternative Routing-ID Interpretation (ARI)
Capabilities: [110] Null
Capabilities: [200] Address Translation Service (ATS)
Capabilities: [420] Physical Resizable BAR
Capabilities: [400] Latency Tolerance Reporting
Kernel driver in use: vfio-pci
Kernel modules: xe
quilt
June 1, 2026, 6:00pm
2
Anything related to the B50 in dmesg and/or journalctl?
The B50 is very tolerant to binding/unbinding even with the xe driver loaded (at least on my system!); I haven’t needed to blacklist xe, bind to vfio on boot, etc. As long as no processes on the host are actively running on the B50 I can pass it through (full device of vf’s). So maybe try that (no blacklisting, vfio shenanigans)
dmesg | grep -i 'intel.*gpu\|xe'
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000154] MTRR map: 6 entries (4 fixed + 2 variable; max 21), built from 9 variable MTRRs
[ 0.000370] e820: update [mem 0xe0000000-0xffffffff] System RAM ==> device reserved
[ 0.004569] [gap 0xe0000000-0xfe9fffff] available for PCI devices
[ 0.346408] ... fixed-purpose counters: 0
[ 0.346411] ... fixed-purpose bitmap: 0000000000000000
[ 0.436380] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfcffffff window]
[ 0.436991] pci 0000:00:01.2: bridge window [io 0xd000-0xefff]
[ 0.441244] pci 0000:20:00.0: bridge window [io 0xd000-0xefff]
[ 0.442078] pci 0000:21:04.0: bridge window [io 0xe000-0xefff]
[ 0.445919] pci 0000:26:00.0: BAR 0 [io 0xe050-0xe057]
[ 0.445924] pci 0000:26:00.0: BAR 1 [io 0xe040-0xe043]
[ 0.445930] pci 0000:26:00.0: BAR 2 [io 0xe030-0xe037]
[ 0.445936] pci 0000:26:00.0: BAR 3 [io 0xe020-0xe023]
[ 0.445942] pci 0000:26:00.0: BAR 4 [io 0xe000-0xe01f]
[ 0.496181] pci 0000:21:04.0: bridge window [io 0xe000-0xefff]
[ 0.496302] pci 0000:20:00.0: bridge window [io 0xd000-0xefff]
[ 0.496329] pci 0000:00:01.2: bridge window [io 0xd000-0xefff]
[ 0.496405] pci_bus 0000:00: resource 9 [mem 0xe0000000-0xfcffffff window]
[ 0.496447] pci_bus 0000:20: resource 0 [io 0xd000-0xefff]
[ 0.496456] pci_bus 0000:21: resource 0 [io 0xd000-0xefff]
[ 0.496464] pci_bus 0000:26: resource 0 [io 0xe000-0xefff]
[ 0.916184] audit: type=1807 audit(1780333896.770:2): action=measure func=KEXEC_KERNEL_CHECK res=1
[ 0.917116] evm: security.SMACK64EXEC
[ 3.811468] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ 4.149505] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
[ 6.262959] snd_hda_intel 0000:30:00.1: bound 0000:30:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 2459.253193] dsl_pool_sync+0xe2/0x510 [zfs]
[ 3196.537529] ? zio_nowait+0xe4/0x1e0 [zfs]
[ 3196.552824] dsl_pool_sync+0xe2/0x510 [zfs]
[ 3196.560805] ? zio_nowait+0xe4/0x1e0 [zfs]
[ 3196.570681] ? zio_nowait+0xe4/0x1e0 [zfs]
[ 3196.594088] ? zio_nowait+0xe4/0x1e0 [zfs]
[ 3196.604667] ? zio_nowait+0xe4/0x1e0 [zfs]
[ 3196.616426] ? zio_nowait+0xe4/0x1e0 [zfs]
and journalctl:
journalctl -k -S "today" | grep -iE 'xe|intel'
Jun 01 19:11:39 virt-domek kernel: Intel GenuineIntel
Jun 01 19:11:39 virt-domek kernel: NX (Execute Disable) protection: active
Jun 01 19:11:39 virt-domek kernel: MTRR map: 6 entries (4 fixed + 2 variable; max 21), built from 9 variable MTRRs
Jun 01 19:11:39 virt-domek kernel: e820: update [mem 0xe0000000-0xffffffff] System RAM ==> device reserved
Jun 01 19:11:39 virt-domek kernel: [gap 0xe0000000-0xfe9fffff] available for PCI devices
Jun 01 19:11:39 virt-domek kernel: ... fixed-purpose counters: 0
Jun 01 19:11:39 virt-domek kernel: ... fixed-purpose bitmap: 0000000000000000
Jun 01 19:11:39 virt-domek kernel: pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfcffffff window]
Jun 01 19:11:39 virt-domek kernel: pci 0000:00:01.2: bridge window [io 0xd000-0xefff]
Jun 01 19:11:39 virt-domek kernel: pci 0000:20:00.0: bridge window [io 0xd000-0xefff]
Jun 01 19:11:39 virt-domek kernel: pci 0000:21:04.0: bridge window [io 0xe000-0xefff]
Jun 01 19:11:39 virt-domek kernel: pci 0000:26:00.0: BAR 0 [io 0xe050-0xe057]
Jun 01 19:11:39 virt-domek kernel: pci 0000:26:00.0: BAR 1 [io 0xe040-0xe043]
Jun 01 19:11:39 virt-domek kernel: pci 0000:26:00.0: BAR 2 [io 0xe030-0xe037]
Jun 01 19:11:39 virt-domek kernel: pci 0000:26:00.0: BAR 3 [io 0xe020-0xe023]
Jun 01 19:11:39 virt-domek kernel: pci 0000:26:00.0: BAR 4 [io 0xe000-0xe01f]
Jun 01 19:11:39 virt-domek kernel: pci_bus 0000:00: resource 9 [mem 0xe0000000-0xfcffffff window]
Jun 01 19:11:39 virt-domek kernel: pci_bus 0000:20: resource 0 [io 0xd000-0xefff]
Jun 01 19:11:39 virt-domek kernel: pci_bus 0000:21: resource 0 [io 0xd000-0xefff]
Jun 01 19:11:39 virt-domek kernel: pci_bus 0000:26: resource 0 [io 0xe000-0xefff]
Jun 01 19:11:39 virt-domek kernel: audit: type=1807 audit(1780333896.770:2): action=measure func=KEXEC_KERNEL_CHECK res=1
Jun 01 19:11:39 virt-domek kernel: evm: security.SMACK64EXEC
Jun 01 19:11:39 virt-domek systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
Jun 01 19:11:40 virt-domek kernel: RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
Jun 01 19:11:40 virt-domek kernel: snd_hda_intel 0000:13:00.0: enabling device (0000 -> 0002)
Jun 01 19:11:40 virt-domek kernel: snd_hda_intel 0000:30:00.1: enabling device (0000 -> 0002)
Jun 01 19:11:40 virt-domek kernel: snd_hda_intel 0000:30:00.1: Handle vga_switcheroo audio client
Jun 01 19:11:40 virt-domek kernel: snd_hda_intel 0000:30:00.6: enabling device (0000 -> 0002)
Jun 01 19:11:40 virt-domek kernel: intel_rapl_common: Found RAPL domain package
Jun 01 19:11:40 virt-domek kernel: intel_rapl_common: Found RAPL domain core
Jun 01 19:11:42 virt-domek kernel: snd_hda_intel 0000:30:00.1: bound 0000:30:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Jun 01 19:11:52 virt-domek kernel: pci 0000:13:00.0: deferred probe pending: snd_hda_intel: couldn't bind with audio component
Jun 01 19:52:34 virt-domek kernel: dsl_pool_sync+0xe2/0x510 [zfs]
Jun 01 20:04:51 virt-domek kernel: ? zio_nowait+0xe4/0x1e0 [zfs]
Jun 01 20:04:51 virt-domek kernel: dsl_pool_sync+0xe2/0x510 [zfs]
Jun 01 20:04:52 virt-domek kernel: ? zio_nowait+0xe4/0x1e0 [zfs]
On my end if I had no blacklisting the xe driver intercepted the device. But sure, will double check that.
oh, damn…. just found this topic - it seems I’m a bit unlucky with this one:
https://community.intel.com/t5/Graphics/Intel-B50-UEFI-boot-issue-on-X470-system/m-p/1733587#M148483
It seems exactly what I’m experiencing - warm reboots and gpu is gone on 5700G. On top of that I’ve indeed noticed the gpu, even though it’s not doing anything is a bit hotter than it should…
So the answer is - you need Vermeer or later CPU for b50
arghhhhhh….
