I need help with a couple recently purchased Intel Arc Pro B60s in my Proxmox system (EPYC 7K62, Supermicro H12SSL-i, 128GB ECC DDR4). I bought the ARKN variants from Newegg (product page) and started noticing issues pretty much right away.
My original plan was to pass them straight through to a VM for local inference using VFIO, but none of the Intel tools I tried, clinfo and the Level Zero tools, were picking them up as GPUs. Because of that I started digging into what the cards looked like from the host side.
That’s where things started looking weird. The PCIe link negotiation for both cards only shows Gen1 x1 at 2.5GT/s. I double checked the usual BIOS settings, Resizable BAR, Above 4G Decoding, SR-IOV support, and made sure all the x16 slots are forced to [x16] instead of [Auto]. None of that changed the link behavior.
I also noticed the card is being reported with about 21GB of VRAM instead of the 24GB listed on the product page. Funny enough, there’s a reviewer on the Newegg page saying they couldn’t get 24GB out of it either, along with this YouTube video.
At this point I’m not really sure where to go next. If anyone has experience getting these cards working properly in a setup like this, I’d appreciate the advice.
Here are some relevant details from what I’ve found so far:
root@proxmox:~# ./gpu_debug.sh
========== SYSTEM ==========
### COMMAND:
uname -r
### OUTPUT:
6.17.13-2-pve
### COMMAND:
pveversion
### OUTPUT:
pve-manager/9.1.6/71482d1833ded40a (running kernel: 6.17.13-2-pve)
### COMMAND:
cat /proc/cmdline
### OUTPUT:
BOOT_IMAGE=/boot/vmlinuz-6.17.13-2-pve root=/dev/mapper/pve-root ro quiet amd_iommu=on iommu=pt pcie_aspm=off pcie_acs_override=downstream,multifunction pci=realloc
### COMMAND:
lscpu | grep 'Model name'
### OUTPUT:
Model name: AMD EPYC 7K62 48-Core Processor
### COMMAND:
dmidecode -t baseboard | grep -E 'Manufacturer|Product|Version'
### OUTPUT:
Manufacturer: Supermicro
Product Name: H12SSL-i
Version: 1.10
========== GPU DEVICES ==========
### COMMAND:
lspci -nn | grep -E 'VGA|3D'
### OUTPUT:
43:00.0 VGA compatible controller [0300]: ASPEED Technology, Inc. ASPEED Graphics Family [1a03:2000] (rev 41)
83:00.0 VGA compatible controller [0300]: Intel Corporation Battlemage G21 [Intel Graphics] [8086:e211]
c1:00.0 VGA compatible controller [0300]: NVIDIA Corporation GB205 [GeForce RTX 5070] [10de:2f04] (rev a1)
c4:00.0 VGA compatible controller [0300]: Intel Corporation Battlemage G21 [Intel Graphics] [8086:e211]
### COMMAND:
lspci -nnk -d 8086:e211
### OUTPUT:
Subsystem: Device [207e:a023]
Kernel driver in use: xe
Kernel modules: xe
Kernel modules: xe
### COMMAND:
lspci -tv
### OUTPUT:
-+-[0000:00]-+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
| +-00.2 Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
| +-01.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
| +-02.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
| +-03.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
| +-03.3-[01]----00.0 Sandisk Corp WD Black SN770 / PC SN740 256GB / PC SN560 (DRAM-less) NVMe SSD
| +-03.4-[02]----00.0 Samsung Electronics Co Ltd NVMe SSD Controller S4LV008[Pascal]
| +-04.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
| +-05.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
| +-07.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
| +-07.1-[03]--+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
| | \-00.2 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PTDMA
| +-08.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
| +-08.1-[04]--+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
| | +-00.2 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PTDMA
| | \-00.3 Advanced Micro Devices, Inc. [AMD] Starship USB 3.0 Host Controller
| +-14.0 Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller
| +-14.3 Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge
| +-18.0 Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 0
| +-18.1 Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 1
| +-18.2 Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 2
| +-18.3 Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 3
| +-18.4 Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 4
| +-18.5 Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 5
| +-18.6 Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 6
| \-18.7 Advanced Micro Devices, Inc. [AMD] Starship Device 24; Function 7
+-[0000:40]-+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
| +-03.3-[41]----00.0 ASMedia Technology Inc. ASM1042A USB 3.0 Host Controller
| +-03.4-[42-43]----00.0-[43]----00.0 ASPEED Technology, Inc. ASPEED Graphics Family
| +-03.5-[44]----00.0 ASMedia Technology Inc. ASM1042A USB 3.0 Host Controller
| +-03.6-[45]--+-00.0 Broadcom Inc. and subsidiaries NetXtreme BCM5720 Gigabit Ethernet PCIe
| | \-00.1 Broadcom Inc. and subsidiaries NetXtreme BCM5720 Gigabit Ethernet PCIe
| +-07.1-[46]--+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
| +-08.1-[47]--+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
| | +-00.1 Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
| +-08.2-[48]----00.0 Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
| \-08.3-[49]----00.0 Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
+-[0000:80]-+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
| +-01.1-[81-84]----00.0-[82-84]--+-01.0-[83]----00.0 Intel Corporation Battlemage G21 [Intel Graphics]
| | \-02.0-[84]----00.0 Intel Corporation Device e2f7
| +-07.1-[85]--+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
| +-08.1-[86]--+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
| +-08.2-[87]----00.0 Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
| \-08.3-[88]----00.0 Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
\-[0000:c0]-+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
+-01.1-[c1]--+-00.0 NVIDIA Corporation GB205 [GeForce RTX 5070]
| \-00.1 NVIDIA Corporation Device 2f80
+-03.1-[c2-c5]----00.0-[c3-c5]--+-01.0-[c4]----00.0 Intel Corporation Battlemage G21 [Intel Graphics]
| \-02.0-[c5]----00.0 Intel Corporation Device e2f7
+-07.1-[c6]--+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
\-08.1-[c7]--+-00.0 Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
========== PCIe LINK STATE ==========
### COMMAND:
lspci -vv -s 83:00.0 | grep -E 'LnkCap:|LnkSta:|LnkCap2:'
### OUTPUT:
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
LnkSta: Speed 2.5GT/s, Width x1
LnkCap2: Supported Link Speeds: 2.5GT/s, Crosslink- Retimer- 2Retimers- DRS-
### COMMAND:
lspci -vv -s c4:00.0 | grep -E 'LnkCap:|LnkSta:|LnkCap2:'
### OUTPUT:
========== BAR / VRAM APERTURE ==========
### COMMAND:
lspci -vv -s 83:00.0 | grep -E 'Region 2|Resizable BAR'
### OUTPUT:
Region 2: Memory at 1e800000000 (64-bit, prefetchable) [size=32G]
Capabilities: [420 v1] Physical Resizable BAR
Capabilities: [220 v1] Virtual Resizable BAR
Region 2: Memory at 000001f000000000 (64-bit, prefetchable)
### COMMAND:
lspci -vv -s c4:00.0 | grep -E 'Region 2|Resizable BAR'
### OUTPUT:
Region 2: Memory at 16000000000 (64-bit, prefetchable) [size=32G]
Region 2: Memory at 0000016800000000 (64-bit, prefetchable)
========== VRAM DETECTED BY XE DRIVER ==========
### COMMAND:
dmesg | grep -E 'VRAM\[|VISIBLE VRAM'
### OUTPUT:
[ 10.962210] xe 0000:c4:00.0: [drm] VISIBLE VRAM: 0x0000016000000000, 0x0000000800000000
[ 10.962245] xe 0000:c4:00.0: [drm] VRAM[0]: Actual physical size 0x0000000540000000, usable size exclude stolen 0x000000053a600000, CPU accessible size 0x000000053a600000
[ 10.962250] xe 0000:c4:00.0: [drm] VRAM[0]: DPA range: [0x0000000000000000-540000000], io range: [0x0000016000000000-1653a600000]
[ 10.962254] xe 0000:c4:00.0: [drm] VRAM[0]: Actual physical size 0x0000000540000000, usable size exclude stolen 0x000000053a600000, CPU accessible size 0x000000053a600000
[ 10.962257] xe 0000:c4:00.0: [drm] VRAM[0]: DPA range: [0x0000000000000000-540000000], io range: [0x0000016000000000-1653a600000]
[ 11.680582] xe 0000:83:00.0: [drm] VISIBLE VRAM: 0x000001e800000000, 0x0000000800000000
[ 11.680700] xe 0000:83:00.0: [drm] VRAM[0]: Actual physical size 0x0000000540000000, usable size exclude stolen 0x000000053a600000, CPU accessible size 0x000000053a600000
[ 11.680704] xe 0000:83:00.0: [drm] VRAM[0]: DPA range: [0x0000000000000000-540000000], io range: [0x000001e800000000-1ed3a600000]
[ 11.680709] xe 0000:83:00.0: [drm] VRAM[0]: Actual physical size 0x0000000540000000, usable size exclude stolen 0x000000053a600000, CPU accessible size 0x000000053a600000
[ 11.680712] xe 0000:83:00.0: [drm] VRAM[0]: DPA range: [0x0000000000000000-540000000], io range: [0x000001e800000000-1ed3a600000]
========== XE DRIVER STATE ==========
### COMMAND:
modinfo xe | grep -E 'filename|vermagic|srcversion'
### OUTPUT:
filename: /lib/modules/6.17.13-2-pve/kernel/drivers/gpu/drm/xe/xe.ko
srcversion: 9DF73FAD15D81C9378B16E4
vermagic: 6.17.13-2-pve SMP preempt mod_unload modversions
### COMMAND:
dmesg | grep -E 'xe .*drm'
### OUTPUT:
[ 10.960229] xe 0000:c4:00.0: [drm] Running in SR-IOV PF mode
[ 10.960461] xe 0000:c4:00.0: [drm] Found battlemage (device ID e211) discrete display version 14.01 stepping B0
[ 11.118986] xe 0000:c4:00.0: [drm] GT0: Using GuC firmware from xe/bmg_guc_70.bin version 70.55.3
[ 11.132091] xe 0000:c4:00.0: [drm] Finished loading DMC firmware i915/bmg_dmc.bin (v2.6)
[ 11.538272] xe 0000:c4:00.0: [drm] GT0: ccs2 fused off
[ 11.538277] xe 0000:c4:00.0: [drm] GT0: ccs3 fused off
[ 11.566086] xe 0000:c4:00.0: [drm] GT1: Using GuC firmware from xe/bmg_guc_70.bin version 70.55.3
[ 11.574804] xe 0000:c4:00.0: [drm] GT1: Using HuC firmware from xe/bmg_huc.bin version 8.2.10
[ 11.587116] xe 0000:c4:00.0: [drm] GT1: vcs1 fused off
[ 11.587120] xe 0000:c4:00.0: [drm] GT1: vcs3 fused off
[ 11.587123] xe 0000:c4:00.0: [drm] GT1: vcs4 fused off
[ 11.587126] xe 0000:c4:00.0: [drm] GT1: vcs5 fused off
[ 11.587128] xe 0000:c4:00.0: [drm] GT1: vcs6 fused off
[ 11.587131] xe 0000:c4:00.0: [drm] GT1: vcs7 fused off
[ 11.587134] xe 0000:c4:00.0: [drm] GT1: vecs2 fused off
[ 11.587137] xe 0000:c4:00.0: [drm] GT1: vecs3 fused off
[ 11.623751] xe 0000:c4:00.0: [drm] Registered 4 planes with drm panic
[ 11.663881] xe 0000:c4:00.0: [drm] Cannot find any crtc or sizes
[ 11.676439] xe 0000:c4:00.0: [drm] Using mailbox commands for power limits
[ 11.676905] xe 0000:c4:00.0: [drm] PL2 is supported on channel 0
[ 11.678699] xe 0000:83:00.0: [drm] Running in SR-IOV PF mode
[ 11.678906] xe 0000:83:00.0: [drm] Found battlemage (device ID e211) discrete display version 14.01 stepping B0
[ 11.743874] xe 0000:c4:00.0: [drm] Cannot find any crtc or sizes
[ 11.783868] xe 0000:c4:00.0: [drm] Cannot find any crtc or sizes
[ 11.849326] xe 0000:83:00.0: [drm] Finished loading DMC firmware i915/bmg_dmc.bin (v2.6)
[ 11.851220] xe 0000:83:00.0: [drm] GT0: Using GuC firmware from xe/bmg_guc_70.bin version 70.55.3
[ 12.267897] xe 0000:83:00.0: [drm] GT0: ccs2 fused off
[ 12.267903] xe 0000:83:00.0: [drm] GT0: ccs3 fused off
[ 12.295326] xe 0000:83:00.0: [drm] GT1: Using GuC firmware from xe/bmg_guc_70.bin version 70.55.3
[ 12.298426] xe 0000:83:00.0: [drm] GT1: Using HuC firmware from xe/bmg_huc.bin version 8.2.10
[ 12.310724] xe 0000:83:00.0: [drm] GT1: vcs1 fused off
[ 12.310729] xe 0000:83:00.0: [drm] GT1: vcs3 fused off
[ 12.310732] xe 0000:83:00.0: [drm] GT1: vcs4 fused off
[ 12.310735] xe 0000:83:00.0: [drm] GT1: vcs5 fused off
[ 12.310737] xe 0000:83:00.0: [drm] GT1: vcs6 fused off
[ 12.310740] xe 0000:83:00.0: [drm] GT1: vcs7 fused off
[ 12.310742] xe 0000:83:00.0: [drm] GT1: vecs2 fused off
[ 12.310745] xe 0000:83:00.0: [drm] GT1: vecs3 fused off
[ 12.347087] xe 0000:83:00.0: [drm] Registered 4 planes with drm panic
[ 12.426868] xe 0000:83:00.0: [drm] Cannot find any crtc or sizes
[ 12.429864] xe 0000:83:00.0: [drm] Using mailbox commands for power limits
[ 12.430327] xe 0000:83:00.0: [drm] PL2 is supported on channel 0
[ 12.466870] xe 0000:83:00.0: [drm] Cannot find any crtc or sizes
========== FIRMWARE ==========
### COMMAND:
dmesg | grep -Ei 'guc|huc|gsc'
### OUTPUT:
[ 12.486910] 0x000000001000-0x00000054e000 : "xe.nvm.50176.GSC"
[ 12.498589] 0x000000001000-0x00000054e000 : "xe.nvm.33536.GSC"
========== DRM DEVICES ==========
### COMMAND:
ls -l /dev/dri
### OUTPUT:
total 0
drwxr-xr-x 2 root root 140 Mar 16 11:26 by-path
crw-rw---- 1 root video 226, 0 Mar 16 11:26 card0
crw-rw---- 1 root video 226, 1 Mar 16 11:26 card1
crw-rw---- 1 root video 226, 2 Mar 16 11:26 card2
crw-rw---- 1 root render 226, 128 Mar 16 11:26 renderD128
crw-rw---- 1 root render 226, 129 Mar 16 11:26 renderD129
========== IOMMU GROUPS ==========
### COMMAND:
find /sys/kernel/iommu_groups -type l | grep 83:00.0
### OUTPUT:
/sys/kernel/iommu_groups/37/devices/0000:83:00.0
### COMMAND:
find /sys/kernel/iommu_groups -type l | grep c4:00.0
### OUTPUT:
/sys/kernel/iommu_groups/16/devices/0000:c4:00.0
========== COMPLETE ==========
Diagnostic output saved to gpu_diag_20260316_121003.txt
root@proxmox:~#
