I’m using apps that benefit from random seeks.
These are Optane devices from Intel.
Is there any reason I can’t use them on an AMD B550 board?
No its just a normal SSD
Thanks.
Just need the U.2 adapter for the M.2 slot.
My M.2 will use a Sabrent PCI-e adapter and sit vertically.
All in a 1U Chassis too.
Happy Camper
Doesn’t one of the 905 sku’s include an m.2 adapter?
Not sure as I put it on a list of purchases, but thanks for the heads up as I will look for that model.
Yes
One sku has a u2 cable, another has m.2 cable.
Unless it was the 900p version? either was too rich for my blood
Found the M.2 on the 480GB version for 600 bucks.
I only keep 350GB’s of data and it’s a 1U build, so I’m fine with the price.
Thanks Again Brotha’ Men…
No reason you can’t use them. This machine here is a Ryzen 3900X using a 905p add-in card. Not U.2.
I would just buy the PCIe card version. Only bother with U.2 if you already have a U.2 drive carrier or that’s the only version you can buy.
Good to hear but I’m building a 1U where the only PCI-e will be a 1X Connector card to a DSP rack.
I’ll use the M.2 Slot for the 905P.
It’s an ASRock B550 Digital Audio Workstation.
Thanks for the reassurance though, much appreciated.
I can’t remember, are you able to boot from an optane drive on Ryzen? I thought that was some proprietary bit from Intel
There are 2 different types of optane ssd’s.
- The optane+nand like that H10
- The optane only, like a 905p
You can use the 905p like any other ssd (Bootdrive, etc), but as far as i know you need an intel to use the H10 fully (optane+nand). May some dirvers can fix this.
Oh excellent. I was thinking of getting an 800p due to reduced prices for some homelab stuff
