Well since Mar I started a project to better assist Model Railroaders use Arduinos to control layouts a lot easier by creating an automated installer. This installer runs cross platform using dotnet core. It allows you to select customization options for your Command Station write those to the config header file then goes thru grpc to run commands using Arduino-CLI to compile and upload the customized sketch. It is all open source and link is below. Not sure what else to say at this point, so I will let you guys have at it.
