First, I want to thank everyone helped me put my first build together. I have my final orders placed and vacation requested so I can enjoy this without being rushed. The last question I have is about setting up my case for the best temps possible. I am considering using front two 120mm fans, the 200mm side fan and a 120mm fan in front of the PSU as intakes. This will leave the rear 140mm and the h100i as exhaust. I have also read that it is better to run this rad in pull so it makes cleaning it easier. I was also planning on mounting the PSU upside down so it draws cool air through the filter from outside the case. Is this a good set up, or am I missing something? Thank you for the help.
Example of H100i set up I am thinking about.
^^^^^^^^^^^^^^^^^- Airflow
-------------------------- - Top Cover
------------------------- - Fans
_______________ - Case
[ ] - H100i
Build: http://pcpartpicker.com/p/wH1p
