Info needed - Thermaltake S500 fans & aio placement
i need some info an advice on fan an aio room an placement in the Thermaltake S500
mount option 1.
for the side vents is ther enough clearence for mounting a 360mm aio thats 38mm thick with a set of 25mm thick fans in the pull config an still mount tree front fans internally rather then external ?
mount option 2. almost the same question as before but can the side fans be mounted externally on the back side between the case a back side panel ?
