Yeah the best thing you can do is get a dock to use with a laptop like that
which kvm do you use? does it support a pair of speakers and webcam and dual monitor simultaneously?
I use a 4-port Display Port kvm that I got from TESmart several years ago
Unfortunately TESmart has completely changed their product line up several times since then and the specific model I have doesnβt seem to exist anymore
I use DP β DP or DP β USB-C for the connections to the computers. For the laptops the USB-C for the monitor + USB-A for the keyboard/mouse is plugged into the OWC Thunderbolt hubs, which then plug into each laptop (MacBook) separately. I have separate OWC Hub for each laptop.
Itβs set up like this
Monitor DP β KVM
Mouse / keyboard β USB hub β KVM
KVM DP / USB-C β OWC Thunderbolt Hub β MacBook (x2)
I have never tried attaching webcam or mic or any other devices as inputs to the KVM to pass through to the computers. Not sure how well that would work, I think the KVM USB-A input is only USB 2.0
