I'm working on a rather involved project that will hopefully turn into an ongoing video series.
Currently I am in need of apartment or house floor plans. They don't have to be yours, they can be pulled from Google for all it matters, I just need a wide variety. Doesn't matter how big the home is, as long as the image contains dimensions for each room, total square footage/meters would also be handy.
Plan I quickly threw together. The bed is a full double. The counters are 50cm deep and the kitchen island is 1m x 1.5m with a 1m gap between it and the counter. The sofas and tv stand aren't necessarily to scale (I just tried to make them recognisable and with not too ridiculous dimensions).
Are original plans of any benefit (as opposed to plans collected from other/random sources)? I could pull out some of my old stuff tomorrow. Used to do a lot of drawing.
The odds of a thread, whereby a known hacker gathers build plans on a government-critical forum, not getting massively red flagged by the NSA, are close to zero.
I just hope it doesn't make the news, y'know, or you could stream 24/7 to make sure you don't miss the swat lolz
I was just kidding mate, I wish you good luck with the development of your forensic impact simulator...
There is an open source automatic plan generator that takes care of all the architectural stuff for you. The only thing you have to do is enter the basic size and location parameters, and the basic requirements, and it generates a flat or house or even an entire skyscraper for you. I'll look for the git later on, when I find it I'll post the link.
