So, I build this PC a while ago - the Killer Panda PC
Let me show you the before pictures, what we are working with here:
The parts before:
Asus Maximus Code X Z370 motherboard
Intel i5 8600K Der8auer Advanced Edition CPU OCed to 5000 MHz
16 (2x8) GB Corsair Dominator Platinum DDR4 2400MHz CL10 RAM (OCed to 3000MHz)
Zotac Amp Extreme GTX 1070 graphics card
Corsair Force MP500 120GB NVME SSD for boot
500 GB HDD for media (I draw a lot)
1TB WD Black for games
240 GB SSD for editing video (I do that too)
Corsair ML120 120mm fans (14 of them!)
Phanteks 120mm Halos Lux fan frames
HW Labs Nemesis GTS 240 white radiator
EVGA SuperNova G2 750watt Gold PSU
Koolance 702 coolant
All sorts of wire extensions to make it pretty.
A panda sticker
A sticker
Bamboo tape
It’s an absolute awesome PC to use
But it’s starting to show its time, mostly because of the 1070…
Pretty damn bad timing! But I found sort of an okay deal, soooo…
I bought a AsRock RX6800XT, the one recently tested on this channel
And THAT’s why I need to re-arrange things, because this graphic card is MASSIVE (the weight alone is 1.815 grams, as in, almost 2KG)
Let me show you what I did…
