I'm Torn Between 2 GPUs For My Build! (Need Help Deciding!)
Tbch man. You not saving much. Looking at the two cards its not just fan size. The fan size is smaller on the gigabyte card but the actual heatsink and cooler has a superior design so it prolly runs cooler anyways.
Gigabyte always has done solid power delivery. I have never bought an MSI graphics card just based on principle. For me I’ve seen them cheap out on things but again I’m very picky when it comes to things like power delivery and cooling because I’m an overclocker. If your not you could save the money get the MSI but if that money is pennies in the dollar for the next level of upgrade then the gigabyte is a bettercard and you should get it cuz you get what you pay for. That’s the way I see it
Here’s the thing. You don’t know now if you will decide to over clock it in the future? Might as well have the headroom. Not to mention seeing that its that particular card branding from gigabyte they prolly put a higher binned chip in there anyways… Again leading to value in longevity.
This is why I still have my 980 Ti’s they were extreme over clocking GPUs so I was able to mod them and push them harder… They knock the socks off of a ton of other systems. I won’t be upgrading for a long while circa say at least the next 3 years… And the 980 Ti’s are maxwells man… So that should basically give you.my logic. However my logic does not need to be your logic :slight_smile:
I won’t touch another GPU until I see truly high end navi and its capabilities from AMD
If the only option is msi or gigabyte, I’d rather give my money to msi. EVGA is a joke since the 10 series. Only Asus cares about not making a junk card it seems.
pick what ever you feel like. gigabyte might have better warranity, evga is what i woulld go after. but i dont use “novideo” cards, so i tend to buy xfx radeon custom bpc cards.
