I'm Torn Between 2 GPUs For My Build! (Need Help Deciding!)
Well, the title basically says it all. I realized about 1 month back that I could save some money on my pc build by going with a third-party GPU over the Founders Edition offered by Nvidia.
At the moment, I’m torn between 2 RTX 2080 cards, but I’m not sure which 1 would be a better deal as I haven’t built a pc before nor have I had much experience with this more modern hardware. So, I’ll be providing a link that is comparing the 2 GPUs I’m trying to decide on. It also boils down to a few questions I have: “Does Gigabyte make better cards or MSI?”, Which of the 2 offers higher-quality products that are a better deal?", etc.
Here is the link for anyone to view if they wish to help me out: https://www.newegg.com/Product/Productcompare?CompareItemList=14-137-375%2C14-932-086
Hope someone can help me make up my mind here & thanks in advance! :slight_smile: Kyle
Just based on price, I think you got your winner right here:
I noticed that of course. But in general, is MSI is better or Gigabyte?
Both companies have good and bad products.
To give you more choice: EVGA is usually the go-to choice for Nvidia cards.
I’ve considered other 3rd-party cards, but I’m mainly torn between the 2 I talked about earlier. Besides, I won’t really be overclocking my GPU anyway… :man_shrugging:
If you’re planning to overclock, the gigabyte is definitely my goto.
Additionally, the gigabyte is 12mm longer. not much, but that’s another 3-4 fins for the heatsink, again, more cooling.
Now, the gigabyte also has a higher base clock, which could indicate higher binned chips, or could be nothing.
So based on the fact that they’re both the same price, I’d recommend the Gigabyte. It’s also got a third fan which should help with cooling capability, assuming your case can handle the heat load.
The power delivery is superior on the gigabyte and so are the quality of the parts. Also Gigabyte like XFX and EVGA dont mind VGA EFI tweaks… so long as you dont exceed the stock power limits…
I definitely would say its a no brainer for the giga
I prefer gigabyte over MSI
Completely subjective:
I have an MSI MB, my xfx r7 250 works great in dual gfx, my MSI r7 250 does not. When I contacted tech support as to why the help was useless.
Since IBM and Compaq left the PC world everything has gone downhill :slight_smile:
I kinda agree with you on that.
You could basically look at the out of the box clock speeds those cards come with.
And based on that you could search for the perfect balance between price and,
out of the box clock speeds.
You could of course go into searching which card is the best overclocker and has the best pcb.
But in the end that is mainly something that die hard extreme tweakers care about.
And not so much the general customer, who just wants to have fun and enjoy the games really.
Next to that those extreme cards are generally significantly more expensive too.
And then you still don’t get any guarantee that it also will overclock decently.
Of course there are cards who have a less decent vrm on the pcb etc.
But yeah does that really justify a significant higher price premium,
if you just wanne enjoy gaming?
Also the fans now days are generally okay on most cards.
I generally agree with this.
How ever i don’t really think that topic starter is generally an extreme over clocker or tweaker.
So yeah although Gigabyte on some models have a better pcb.
It’s still arguable if that would really be worth paying an extra premium for in this case.
I can speak to the Ventus. Solid/ silent card but I have yet to overclock it. In spite of it looks, been a decent card.
Yeah, MisteryAngel assumed correctly since I stated earlier that I don’t really want to overclock/tweak my cards just yet; I simply want to enjoy just a fantastic gaming experience! :smiley: But can anyone speak from personal experience as to which card performs better out of the box, which 1 is higher-quality, has a better warranty, etc? I’d love to hear your thoughts & experiences, guys! And thanks for the responses & your help so far! :slight_smile:
If I had to venture a guess… The msi has a lower core clock verses the gigabyte. That almost means nothing till overclocked.
Some of this is in your post.
In Stock Yes Yes
Item# Multiple Multiple
Model# GV-N2080WF3-8GC RTX 2080 VENTUS 8G
Brand GIGABYTE MSI
Interface PCI Express 3.0 x16 PCI Express 3.0 x16
Chipset Manufacturer NVIDIA NVIDIA
GPU Series NVIDIA GeForce RTX 20 Series NVIDIA GeForce RTX 20 Series
GPU GeForce RTX 2080 GeForce RTX 2080
Core Clock 1710 MHz 1515 MHz
CUDA Cores 2944 2944
Effective Memory Clock 14000 MHz 14 Gbps
Memory Size 8GB 8GB
Memory Interface 256-Bit 256-Bit
Memory Type GDDR6 GDDR6
DirectX DirectX 12 DirectX 12
OpenGL OpenGL 4.5 OpenGL 4.5
HDMI 1 x HDMI 2.0b 1 x HDMI 2.0b
Multi-Monitor Support 4 4
DisplayPort 3 x DisplayPort 1.4 3 x DisplayPort 1.4
Other Ports 1 x USB Type-C (support VirtualLink) 1 x USB Type-C
Max Resolution 7680 x 4320 @ 60 Hz 7680 x 4320
SLI Support 2-way NVIDIA NVLINK NVIDIA NVLINK (SLI-Ready), 2-way
Virtual Reality Ready Yes Yes
Cooler WINDFORCE 3X Double Fans
Thermal Design Power 215W 215W
System Requirements System PSU Limitation: 650W Recommended PSU: 650W
Power Connector 1 x 6-Pin, 1 x 8-Pin 1 x 8-pin, 1 x 6-pin
Features Powered by GeForce RTX 2080
Integrated with 8GB GDDR6 256-bit memory interface
WINDFORCE 3X Cooling System with alternate spinning fans
RGB Fusion 2.0 - synchronize with other AORUS devices
Metal Back Plate Customized Dual Fan Design
  • Double ball bearing: Strong and lasting core for years of smooth gaming.
  • Smooth Heat Pipes: Squared shape at bottom maximize heat transfer from the copper base plate.
Afterburner Overclocking Utility
  • Wireless control through Android/iOS devices.
  • Predator: In-game video recording.
  • Kombustor: DirectX12 benchmark.
  • Supports multi-GPU setups.
NVIDIA G-SYNC and HDR
  • Get smooth, tear-free gameplay at refresh rates up to 240 Hz, plus HDR, and more. This is the ultimate gaming display and the go-to equipment for enthusiast gamers.
GeForce RTX VR
  • By combining advanced VR rendering, real-time ray tracing, and AI, GeForce RTX will take VR to a new level of realism.
    Form Factor ATX
    Max GPU Length 280 mm 268 mm
    Card Dimensions (L x H) 11.04" x 4.58" 10.55" x 4.49"
    Slot Width Dual Slot
    Boost Clock 1710 MHz
    HDCP Ready 2.2
Msi has a three year warranty and a popular overclocking software.
Msi is shorter card with dual larger fans
Hm. So the Gigabyte card is clocked higher & meant for overclockers. But you mentioned the MSI card has “dual larger fans”. So you mean it’s fans are bigger than the ones on the Gigabyte card? Do you think MSI is a more logical choice for my needs or should I just get the Gigabyte card? [In case anyone needs further details, I should mention I’ll be gaming in 1440p resolution at max/ultra details. But I don’t think I’ll be running any AAA titles. Anyway, if you need to ask me anything, I’m here & I’ll be sure to provide you with any additional details!] :slight_smile:
Depends on the price in general really.
I have not looked at the said particular cards you listed.
But if the Gigabyte has a significant higher base clock,
and the price difference is minor.
Then it could be worth it to go for the Gigabyte card then.
However if the price difference is lets say $50,- more,
then i personally wouldn’t really bother.
Since you could buy a very cool game for that money.
EVGA like mentioned above also make sollid cards.
So i would definitelly say take a look at those aswell.
I suspect the higher base clock means less overclocking. The MSi has lower base clocke but boost to the same.
Higher or lower base clocks
Gigabyte is longer card with three smaller fans… might mean more noise ?
I imagine both will preform about the same.
I also game at 1440p in large mmo’s. A single 2080 does well.
Msi card often goes on sale and is cheaper… other than that ? Its fairly quiet card and performs within its rating. No heat issues. Runs fairly cool without any tweaking. I think that this Msi 2080 is certainly not an over clockers card. Better ones out there but they will cost more.
Yeah i´m not fully sure.
But it looks to me that the Msi RTX2080 Ventus is likely,
just a reference pcb (or very similar) with a third party cooler.
Because the Msi RTX2080 Gaming Trio is a custom pcb,
with pretty much the same vrm components as the reference pcb,
with two more phases for Vcore, 10 phases instead of 8 phases for a reference RTX2080.
But i´m still looking for exact pcb info of the Msi RTX2080 Ventus.
So don´t pin me on my statement just yet.
I never looked at the pcb lay out that close :)~ I do not have any plans to extreme overclock it.
When I purchased it I thought oh crap… a cheap plastic looking noisy card… I was surprised and wrong.
Yeah like i mentioned above, all that custom extreme pcb,
generally only really matters of you are an extreme overclocker.
For the normal gamer who just want to enjoy gaming,
are generally not really bothered with extreme overclocking,
tuning and tweaking.
So yeah unless you got a card with really loud and crappy fans.
But in this day and age i have not really seen that very often anymore.
Only those blower style reference coolers…
