i have fx 8350
case is coolermaster 310
please suggest me a cooler which fits in my case and with which i can overclock
+ *NOTE MY ROOM TEMPRATURE IS USALLY 34 c SO I NEED A HELL GOOD COOLER*
thanks in advance
also please suggest one from flipkart.com as i live in india
If you want the best of the best, the Noctua NH-D14 is the best. And it will fit in your case.
http://www.flipkart.com/noctua-nh-d14/p/itmd7j42gkhx4euy?pid=COLD7J42UGDAXKNG&ref=1deecaaf-18eb-4da0-84c9-e4b94aa45f28&srno=t_2&otracker=from-search&query=noctua%20nh-d14
However, if you have RAM with large heatsinks, the D14 may not fit. In that case, your best option (because Flipcart has barely any coolers in stock) would be the Antec Kuhler 620. It won't perform as well as the D14, but it won't block your RAM.
darn it its out of my budget my budget is 2500 rs
and i do not know how to setuo water cooler
