If you're using an ASUS motherboard and run linux…
… you could help me out.
I was looking at the asus_atk0110 driver when trying to figure out why fan control is not possible on my ASUS M5A78L-MUSB3 and it comes down to the fact that the IC on the MB which is responsible for hardware monitoring and fan control is taken exclusive control over by the BIOS so the kernel has to communicate with the BIOS over ACPI instead of talking with the chip directly.
The asus_atk0110 driver does this but is only reading sensors and nothing else. There is no documentation for the ASUS ACPI tables, which means they have to be reverse engineered.
This is where I need your help: I want the ACPI tables for as many ASUS motherboards (and BIOS versions) as possible.
We've got the tables for
What you can do: dump your ACPI tables, upload them somewhere, and post a link here with your motherboard name and BIOS version.
How to I get the ACPI tables?
Install acpidump (on Debian based systems: sudo apt-get install acpidump), execute
sudo acpidump > acpi.dat
The file acpi.dat now contains everything needed. This is just a text document so you could use a pastebin to upload it.
Thanks in advance for your help. If you guys have any questions, go ahead.
bump.
Nobody with an ASUS motherboard using Linux?
MB: Asus M5A78L-M/USB3
Bios version: 1801
Google Drive link: https://goo.gl/iNpK5e
It's not the latest BIOS and the ACPI table showed some BIOS bugs or something, I don't know what those are about.
Do you use some utility to control the fan speeds?
I'll post another motherboard tomorrow, if I don't forget.
MB: Asus Z87-PRO
Bios version : 1802
Google Drive : https://drive.google.com/folderview?id=0B2WDfVM3V_KPcVlyaGllU1NZRlE&usp=sharing
Thank you very much!
I've got the exact same motherboard, the md5sum of the tables is different but there is no diff in the important parts when disassembled.
It's currently impossible to control the fan speeds on ASUS motherboards with linux (I'm not sure if all work the same way with ACPI, so that's what I want to figure out). The BIOS takes full control over the fan control and hw monitoring chip so we have to tell the BIOS what to do. On the M5A78L-M/USB3 is looks like the only option is to change the Q-FAN mode (this can be done in the BIOS but it would be nice to be able to change it on the fly).
I've also seen another ASUS motherboard with more control options in ACPI. This is really about understanding all possible features and values in the fan device class.
Maybe I'm too stupid for google drive, but it wants me to login as someone else. Maybe you have to create a link to share?
Yeah never used drive try it out now, let me know
Sorry, still not working.
Ok second attempt to share the file , go for it.
Fingers crossed
It's working! Thanks!
So I've taken a look at the Asus Z87-PRO ACPI tables and it looks like it's using the ThermalZone standard instead of proprietary ASUS ACPI functions.
This is good because it should work out of the box:
/sys/class/thermal/thermal_zone[0-*] should contain the sensors
/sys/class/thermal/cooling_device[0-*] should contain cooling devices
@epsilont, could you check if those files/directories exist?
This means that somewhere in between the M5A78L-M/USB3 and the ASUS Z87-PRO they changed the way they handle sensors and fans. Would be nice to find out when this happened.
No ASUS motherboard here. However, if its not a big ask it would be really interesting to know how you go about doing this, creating the driver and such, I assume you'll be submitting a patch of you get it working as well?
Yes I have those : /sys/class/thermal/thermal_zone[0-* for 5 of them (fans)
and /sys/class/thermal/cooling_device[0-* for 3 of them
Great, thanks. That already narrows down the number of motherboards to check.
@Eden, creating and pushing the driver into the kernel is probably going to be way easier than figuring out ASUS' proprietary ACPI stuff. I'll keep you guys updated but I need more data and help first.
BIOS Info: #0
Vendor: "American Megatrends Inc."
Version: "2501"
Date: "04/09/2014"
Board Info: #2
Manufacturer: "ASUSTeK COMPUTER INC."
Product: "M5A97 EVO R2.0"
And the acpi.dat file (I have no thermal_zone devices in /sys/class/thermal)
https://filetea.me/t1sxxdqlJtjTpqUOlIvNpm9Lg
Good luck!
Would an Asus B85M-G be of any help?
Couldn't find acpcidump for Manjaro, but acpica from AUR has it included
Asus M5A78L-M LX3 - BIOS v1201 - acpi.dat
fyi bf77b00c5ac42829b509 did respond here under another name but its been completely removed. I forget what they said. don't expect anything to come of this topic for a while.
Might be a bit old...
M2N68-AM plus, http://paste.ubuntu.com/13293920/
MB: Asus M5A97 PRO
Bios version: 1604
Google Drive link: https://goo.gl/CesaOe
I can do it to a H81m and a Z97-A, would either of those be any help?
