Hi all
I tried searching the web and almost instantly got quite frustrated by the results with so many people saying that you should just not connect the Smart TV to a network.
In short, I’m looking for suggestions or ideas on how I can get my hands on like a 42 inch dumb monitor that won’t bankrupt me. I don’t care about things like HDR or dimming zones, it’s too expensive for me anyway… I just want a simple monitor to watch movies, series, and youtubes and a 42 inch display at 1080p will do just fine I think and will already be a huge upgrade over what I have been using.
Last night while in bed I started to wonder if I could maybe get a different controller board and then I could ditch all the “smart” crap, but then it got me wondering if such dumb/non-smart displays is even something we as consumers can still get? I got lucky with the 32 inch one I have years ago, but after a quick online search I just get results for smart TVs.
The obvious option would be a smart tv and to not connect to anything, but after 2 days with a 42 inch Samsung smart tv that is not connected to any network… I’ve decided it has to go. What a POS. ![]()
For those interested, here be the rant:
Summary
I’ve used an old 32 inch monitor for many years now. It was designed and built to run 24/7 in shopping centers and as such it has a ton of connection options, you can daisy chain a bunch of them together, and it can get very bright, but that comes at the cost of power draw and heat. So much heat, that it will heat up the room it’s in. From memory, I believe it can pull over 900w. It’s a Goodview m32h, but I can’t find specs for it anymore.
So I decided that I’d like something a little bigger and that does not double as a heater and got a second hand Samsung 42 is “smart” TV. This is the first LCD tv I have ever owned and had no idea what to look out for when buying one. I turned the TV on when I went to look at it and the app started up and it all seemed to look and work fine… but… after I got it home I saw something similar to this…
You can only see the LEDs in bright scenes like an image of a bright blue sky and it’s not dimming zones. For the most part I don’t really see these spots, but every now and then there will be a bright scene and then I cannot not see them. Turns out, it’s a common issue, but that’s not the worst of it…
It’s messing with my bluetooth headset and there seems to be no way to turn the TV’s wifi and bluetooth completely off which not all that smart. I’m not 100% sure it’s the TV, but this is the firs time I’ve had issues with the BT and the issues seem to go away when the TV is unpowered…
The TV is connected to my PC with HDMI, but it’s turned off and I’ve set Windows to NOT extend my display to it. This morning, while on a Teams call with work, my PC screen flickered and I lost auto for about 1 second. Then it happened again, and again, and then I lost audio completely. I open up sound settings to find that the TV is now my default audio output… yes… the TV that is suppose to be off. I switched it off at the plug and it stopped trying to take over my PC. What the hell??? ![]()
I couldn’t make it 2 days with a “smart” tv that is NOT connected to any network which I guess is kinda funny, but I also want to snap the thing in half like it’s twig.
