Ok I currently have a LGA2011 mobo with an i7-3820. I'm thinking about upgrading my CPU to the i7-4820 but I can't decide whether or not I should. It's around $370 and I'm not sure it'll make a $370-worth difference. What do you guys think?
I would advise against it. The performance difference between the two is almost negligible, and the 3820 overclocks slightly better then the 4820.
well the 4820K will overclock better because it has an unlocked multiplier, which the 3820 doesn´t have!
Is it worth upgrading? In my opinnion NO, because the performance diffrence isn´t realy big, the best upgrade for you would be a I7-4930K. But this only comes handy if you do heavy productivity, for only gaming its useless, because 3820 vs 4930K in gaming is only a 2 FPS bumb. the only big plus with ivy-bridge-e cpu´s is that the pci-e lanes are GEN 3.0. so if you work with quad gpu´s or pci-e fast raid cards etc, then it could be worth it.
Grtz angel ☺
Dif in performance between the 3820 and 4820K is 8-11%. Wouldn't pay $100 for that upgrade lol. With how little performance changes now between generations and how overclocking headroom seems to be less each coming year, I'd say stick with the 3820 for a few years unless you need DDR4 then upgrade to Haswell-E. If you really need something with more horsepower grab a 4930k
