Hi community,
hopefully I'm posting in the correct section here, my first topic at all here :D
So I have Nexus5 and it had like 2second reboots I cleaned the powerbutton with 99% rubbing alcohol yeah it worked again and I was hey let's clean the other connectors too... well didn't go that well.
Then I had such blue ink looking dots on that LCD, but it still works and looks ugly+not very bright anymore. I used to hairdry that device like no tomorrow and the blue ink got away and instead I have now such darker to bright sections.
I thought if this stays I gonna bath that thing in rubbing alcohol(of course without battery) to get atleast one brightness level.
I wanna note here that stuff kinda moves a bit if a lot pressure is applied.
Does 99,9% isopropyl damage LCD's?
IDK if this goes away since 1 day I don't see any change anymore(3days by now). Is there anything I can do, other than getting a 150€ screen replacement? Sry for the english(if you encounter issues, I'm not native)
Update: Now it's in a box of rice(Does this even help with 99,9% rubbing alcohol?.
MfG Legion495
