im running pop os on my aorus b450m with a 6700xt an recently after a bios update an cpu upgrade to the 5600g i lost the ability to under-volt my gpu when using corectrl now as before the voltage slider shows up
but unlike before has no effect
two things to note that may be at fault either 1 or the other or both or not all is this before the cpu an bios upgrade the grub boot-loader was used with these tweaks were use but only needed the
all f ppfeaturemask to get full adjustable gpu control with corectrl but now to get almost full control accept for the voltage offset not having no effect both of the listed mask lines must be used , in the
default boot-loader i couldn’t get the grub loader reinstalled right 2 an this has to do with the mobo is the a setting in a advanced menu the can effect the dedicated 6700xt gpu that would prevent the manual
voltage control offset from working right an is ther is what,were , an how do i change it
