I thought I would be safe with the power supply I chose for this build but after doing some reading I'm not sure if it has enough amps on the +12v rail.
The GPU takes 35 Amps, the stock one at least, and I plan to overclock it more. I also plan to overclock the CPU as far as is safe. I know the 600 watts on the PSU is enough, but I'm not sure about the amperage on the +12v rail. So my question, will 46 Amps be enough +12v juice to power an OC'd HD7850, OC'd X4 965 BE, and the rest of a system?
