I need help finding a Gotek that ships out of the NA region
Theres no vintage section yet so I’m just sticking this in hardware.
The fuck is a gotek?
This is a Gotek
Stick it in your computer of choice, put USB in it, there you go.
I need help finding NA ones compatible with an Amiga A2000 because anything coming over seas would take like 2 months because of the hurricane and I don’t have that kind of time for what I am doing. I know there are sites like Amiga On The Lake but they don’t have any Gotek Drives. Could I reprogram one? Sure. Do I know how or have the ability? Fuck no.
So if you have any idea of any Gotek drives out of America that would just be swell. Otherwise I’ll just buy one off of amigakit and call it a day.
Does this fit the bill? Seller is in LA
Ah, heh, no thats a DOS one I believe. Needs to be amiga compatible.
IDK maybe theres an easy way to flash them?
Thats the problem with Gotek’s: Theres fucking 8 billion of them.
How about this one, Claims tested with a 500. Ships from Kanuckistan.
http://www.ebay.com/itm/Amiga-USB-Floppy-Disk-Emulator-GOTEK-beige-w-8GB-USB-key-/172782656146?hash=item283aa61a92:g:e1gAAOSwd2xXP8Oo
I will check it out later I need to get to something real quick.
TY!!
