take a small flat head screwdriver, take out all the cables from the front panel, then keeping your hands on the insulated part of the screw driver, go along each horizontal pair of pins when it turns on, that is the pair you need to put the power switch to
Thank you for the replies Ookami and gigabusterEXE.
Ookami: i will let the thread starter the chance to answer that
gigabusterEXE: http://i50.tinypic.com/35chhqg.png those are the pins he is jumping for startup, it looks proper to us can you take a look? would shorting out the pins horizontally cause any possible issues?
