Assuming this is the patch you are using:
diff --git a/Documentation/admin-guide/kernel-parameters.txt b/Documentation/admin-guide/kernel-parameters.txt
index 7bc83f3d9bdf..3174f3bd126a 100644
--- a/Documentation/admin-guide/kernel-parameters.txt
+++ b/Documentation/admin-guide/kernel-parameters.txt
@@ -3509,6 +3509,15 @@
nomsi [MSI] If the PCI_MSI kernel config parameter is
enabled, this kernel boot option can be used to
disable the use of MSI interrupts system-wide.
+ pcie_acs_override =
+ [PCIE] Override missing PCIe ACS support for:
+ downstream
+ All downstream ports - full ACS capabilities
+ multfunction
+ All multifunction devices - multifunction ACS subset
+ id:nnnn:nnnn
+ Specfic device - full ACS capabilities
+ Specified as vid:did (vendor/device ID) in hex
noioapicquirk [APIC] Disable all boot interrupt quirks.
Safety option to keep boot IRQs enabled. This
should never be necessary.
diff --git a/drivers/pci/quirks.c b/drivers/pci/quirks.c
index ca9ed5774eb1..dae6f719cf84 100644
--- a/drivers/pci/quirks.c
+++ b/drivers/pci/quirks.c
@@ -3544,6 +3544,106 @@ static void quirk_no_bus_reset(struct pci_dev *dev)
dev->dev_flags |= PCI_DEV_FLAGS_NO_BUS_RESET;
+static bool acs_on_downstream;
+static bool acs_on_multifunction;
+#define NUM_ACS_IDS 16
+struct acs_on_id {
+ unsigned short vendor;
+ unsigned short device;
+static struct acs_on_id acs_on_ids[NUM_ACS_IDS];
+static u8 max_acs_id;
+static __init int pcie_acs_override_setup(char *p)
+ if (!p)
+ return -EINVAL;
+ while (*p) {
+ if (!strncmp(p, "downstream", 10))
+ acs_on_downstream = true;
+ if (!strncmp(p, "multifunction", 13))
+ acs_on_multifunction = true;
+ if (!strncmp(p, "id:", 3)) {
+ char opt[5];
+ int ret;
+ long val;
+ if (max_acs_id >= NUM_ACS_IDS - 1) {
+ pr_warn("Out of PCIe ACS override slots (%d)\n",
+ NUM_ACS_IDS);
+ goto next;
+ p += 3;
+ snprintf(opt, 5, "%s", p);
+ ret = kstrtol(opt, 16, &val);
+ if (ret) {
+ pr_warn("PCIe ACS ID parse error %d\n", ret);
+ goto next;
+ acs_on_ids[max_acs_id].vendor = val;
+ p += strcspn(p, ":");
+ if (*p != ':') {
+ pr_warn("PCIe ACS invalid ID\n");
+ goto next;
+ p++;
+ if (ret) {
+ goto next;
+ acs_on_ids[max_acs_id].device = val;
+ max_acs_id++;
+next:
+ p += strcspn(p, ",");
+ if (*p == ',')
+ p++;
+ if (acs_on_downstream || acs_on_multifunction || max_acs_id)
+ pr_warn("Warning: PCIe ACS overrides enabled; This may allow non-IOMMU protected peer-to-peer DMA\n");
+ return 0;
+early_param("pcie_acs_override", pcie_acs_override_setup);
+static int pcie_acs_overrides(struct pci_dev *dev, u16 acs_flags)
+ int i;
+ /* Never override ACS for legacy devices or devices with ACS caps */
+ if (!pci_is_pcie(dev) ||
+ pci_find_ext_capability(dev, PCI_EXT_CAP_ID_ACS))
+ return -ENOTTY;
+ for (i = 0; i < max_acs_id; i++)
+ if (acs_on_ids[i].vendor == dev->vendor &&
+ acs_on_ids[i].device == dev->device)
+ return 1;
+ switch (pci_pcie_type(dev)) {
+ case PCI_EXP_TYPE_DOWNSTREAM:
+ case PCI_EXP_TYPE_ROOT_PORT:
+ if (acs_on_downstream)
+ return 1;
+ break;
+ case PCI_EXP_TYPE_ENDPOINT:
+ case PCI_EXP_TYPE_UPSTREAM:
+ case PCI_EXP_TYPE_LEG_END:
+ case PCI_EXP_TYPE_RC_END:
+ if (acs_on_multifunction && dev->multifunction)
+ return 1;
+ return -ENOTTY;
* Some Atheros AR9xxx and QCA988x chips do not behave after a bus reset.
* The device will throw a Link Down error on AER-capable systems and
@@ -4796,6 +4896,7 @@ static const struct pci_dev_acs_enabled {
{ PCI_VENDOR_ID_ZHAOXIN, 0x9083, pci_quirk_mf_endpoint_acs },
/* Zhaoxin Root/Downstream Ports */
{ PCI_VENDOR_ID_ZHAOXIN, PCI_ANY_ID, pci_quirk_zhaoxin_pcie_ports_acs },
+ { PCI_ANY_ID, PCI_ANY_ID, pcie_acs_overrides },
{ 0 }
You can change it to:
+ downstream
+ multfunction
+ id:nnnn:nnnn
+struct acs_on_id {
+ if (!p)
+ return -EINVAL;
+ while (*p) {
+ char opt[5];
+ int ret;
+ long val;
+ NUM_ACS_IDS);
+ goto next;
+ p += 3;
+ if (ret) {
+ goto next;
+ if (*p != ':') {
+ goto next;
+ p++;
+ if (ret) {
+ goto next;
+ max_acs_id++;
+next:
+ if (*p == ',')
+ p++;
+ return 0;
+ int i;
+ return -ENOTTY;
+ return 1;
+ return 1;
+ break;
+ return 1;
+ return -ENOTTY;
/* Wangxun nics */
