His point is that if the card is rendering out 200fps, then that 200th frame will be closer to real time then whats would be shown if the card was putting out exactly 60fps. Also if you have played cs:go, you'd know that the game is very good about dealing with screen tears. I run at 400fps on my 144hz screen and it doesn't tear at all. The game is just made pretty well in that regard.
This is true. I play on 60Hz capped at 121fps. Not tearing at all really. The point isn't to see the frames but to have smoother input.
PCPartPicker part list: http://pcpartpicker.com/p/wXvMxr
Price breakdown by merchant: http://pcpartpicker.com/p/wXvMxr/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core OEM/Tray Processor ($218.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($32.50 @ Newegg)
Motherboard: Gigabyte GA-Z97MX-Gaming 5 Micro ATX LGA1150 Motherboard ($104.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($49.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($99.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($48.75 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card ($302.00 @ Newegg)
Case: Phanteks Enthoo EVOLV MicroATX Mini Tower Case ($109.99 @ Newegg)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.99 @ NCIX US)
Total: $1012.19
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-05-17 10:42 EDT-0400
Here's another option, this time ITX:
PCPartPicker part list: http://pcpartpicker.com/p/Tj2dWZ
Price breakdown by merchant: http://pcpartpicker.com/p/Tj2dWZ/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($177.99 @ SuperBiiz)
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard ($72.98 @ Newegg)
Memory: Team Dark 8GB (1 x 8GB) DDR3-1600 Memory ($43.99 @ Newegg)
Case: Phanteks Enthoo EVOLV ITX Mini ITX Tower Case ($69.99 @ Newegg)
Power Supply: Antec EarthWatts Platinum 550W 80+ Platinum Certified ATX Power Supply ($50.99 @ Newegg)
Total: $899.18
Generated by PCPartPicker 2015-05-17 10:52 EDT-0400
You won't regret it.
The build is mostly for CS:GO and he did say streaming which could also mean recording and that means lots of footage. Plus any more powerful GPU is useless in a source engine game.
Aye. If he's only going to be playing CS:GO, fine, but there's other games out there he'll defo see a performance increase in for going with a 290 over a 960 obviously. It's not like it's going to be exclusively a CS:GO machine that nothing gets played on, I doubt.
Going for an r9 290 would probably imply that you're playing at 1440p. Also trust me there are about 4 people on my steam friends list that only play DotA 2 and maybe war thunder for five minutes a year.
Actually there is a very small difference/advantage.
and in a fast paced game like CS a lot of people notice it.
I'm talking The latency from you giving the computer input to the image being display.. At 60hz one frame takes 16.66ms top render this doesn't count for other latencies in the system
If you're running 200+ fps you render time per frame is 5ms That more than 10ms of lowered latency that you * can * feel
