my system:
X9DR3-F e5 2697v2 x2 Power 750W
It doesn’t start with GPU AMD Firepro s7150 X2. Stops at the stage “System initializing 91”
Another system:
GA-AX370-Gaming 5 Ryzen 1800X
Stops at the stage 06 (LED on motherboard)
Everything works without Firepro
I thought the GPU was broken, but today I tried it on another system:
asus kgpe-d16 opteron 6378
And oh amazing - my GPU FirePro s7150x2 works)))
I think the problem is in SR-IOV support.
how do I enable SR-IOV in the BIOS on X9DR3-F motherboard? I didn’t find anything like that.
what do you think about it?
I was able to build the driver, but I can’t install it.
`master@Beast:~$ sudo /home/master/gim/gim.sh
[sudo] пароль для master:
Current User is root
/home/master/gim/gim.sh: 28: [: -ne: unexpected operator
check: /usr/src/linux-headers-5.4.0-65-generic
/home/master/gim/gim.sh: 37: [: /usr/src/linux-headers-5.4.0-65-generic: unexpected operator
make -C /lib/modules/5.4.0-65-generic/build M=/home/master/gim/drv modules
make[1]: вход в каталог «/usr/src/linux-headers-5.4.0-65-generic»
Building modules, stage 2.
MODPOST 1 modules
make[1]: выход из каталога «/usr/src/linux-headers-5.4.0-65-generic»
make -C /lib/modules/5.4.0-65-generic/build M=/home/master/gim/drv modules_install
INSTALL /home/master/gim/drv/gim.ko
At main.c:163:
SSL error:0909006C:PEM routines:get_name:no start line: …/crypto/pem/pem_lib.c:745
sign-file: certs/signing_key.pem: Success
DEPMOD 5.4.0-65-generic
Warning: modules_install: missing ‘System.map’ file. Skipping depmod.
master@Beast:~$
`INSTALL /home/master/gim/drv/gim.ko
At main.c:160:
SSL error:02001002:system library:fopen:No such file or directory: bss_file.c:175
SSL error:2006D080:BIO routines:BIO_new_file:no such file: bss_file.c:178
sign-file: certs/signing_key.pem: No such file or directory
DEPMOD 4.15.0-133-generic
make[1]: выход из каталога «/usr/src/linux-headers-4.15.0-133-generic»`
What am I doing wrong?
Where is the Linux guru? Are you very busy?
Hi, someone have the orignal bios for the AMD Firepro s7150 X2 ?
i try the new on techpowerup they don’t work and i don’t make a backup
Thanke for your help.
