So I tried to enable Hyper-V on Windows 10 Pro and then tried running Bluestacks 5, it kept freezing/locking up the computer when Bluestacks loaded.
I had to remove the Hyper-V app and reboot in order to get back to normal.
Bluestacks detected Hyper-V being enabled and running and had me download the so-called compatible version for both 32-bit and 64-bit OS’s
However they both behaved the same way until I removed Hyper-V
Any ideas on this one ?
I wanted to try out Hyper-V as a replacement for VMware Player.
Hyper-V requires complete access to the Virtualization extensions, and only allows what is called “User Mode Virtualization”. Perhaps this is what’s truly causing the issue?
Bluestacks does have a page for this specific topic: https://support.bluestacks.com/hc/en-us/articles/4412148150157-Solution-for-when-BlueStacks-5-is-unable-to-launch-when-Hyper-V-is-enabled
Yeah, this is a known issue, Bluestacks at all on Windows 11 requires the same work-around, and using it precludes the ASW as well.
Thanks for the feedback.
I will check out that article and see what to try out.
I reviewed the article and tried what was mentioned there, same issue.
I will research this matter further when I get time but was also wondering of any other Windows Host based alternative to VMware ?
Is Oracle doing the same thing with VirtualBox ?
VirtualBox also uses User Mode Virtualization when running at the same time as Hyper-V… but you could always run VirtualBox directly without any Hyper-V shenanigans, that could make your use case work!
@teltersat thanks for the feedback, I will test this out.
