Huge driver issues MSI MEG x399 creation and gtx 1060
Hi Everyone,
I am new to linux, however I always wanted to have a dual boot windows/linux computer, so I finally got myself one. The parts are listed here Your Account - PCPartPicker. I updated the BIOS on that beast of motherboard (I am planning on some major upgrades down the line).
The parts arrived and I assemple it, boot the bios and everything was present, so I felt a huge relieve. I tried to install windows and linux, however I had the blue screen of death after the first instalation section of windows, which I though was odd. So instead I started with Linux.
It crashed as soon as I log in (I asked for it to install third party propietary software). After that I install without that option and It work like a charm.
However the wifi card was not recognized (Intel® Wireless-AC 9260 card ) but the bluetooth works perfectly. I downloaded the linux firmware from intel and I moved it to the /lib/firmware folder separately and also as individual files and nothing worked.
I also updated all linux packages and everyone and nothing has work.
I am truly lost, any help will be great, also I am a complete linux novice
EDIT
Thank MisteryAngel, I installed Ubuntu. I also updated all the packages:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
Kinda hard to help if we dont know which particular distro you use.
As for Nvidia you probablly need to install the Nvidia 415 driver.
Hi, thank for the reply! I installed ubuntu ( not ready for the other distros) and thank you I fixed the grafics cards and I installed the driver.
