HP Prodesk refuses to Post with Intel i350T4 installed
Hi,
I recently acquired three HP Prodesk G1’s with Dual Core Pentiums and 8GB RAM each almost for free on a flee market.
They’re great to experiment around with and are good on power usage too.
While I’m on the hunt for new rackmountable opnsense hardware, I figured I’d use one temporarily as a router, with an i350T4 installed instead of an old Optiplex that uses 40W idle.
Problem:
  • With Network Card installed, the Prodesk will on random occasion refuse to post
  • Only the Power LED on Mobo lights up when power is plugged in, none of the boot indicator LEDs show anything
  • Once the issue occurs, I have to remove power, reset the CMOS to get it to post/boot again
  • The issue occurs on all three of the machines, as long as Network Card is installed
Things I’ve tried so far:
  • Change Various BIOS Settings which might be related, reset the BIOS
  • Tape over Pins B5/B6 on the PCIe Card with Electrical Tape to avoid potential SMBUS issues
  • Replace RAM, use different RAM configuration
The Network Card works fine with a Supermicro x9 Mobo, Z490 Mobo as well as an Dell Optiplex from the same era. As far as I managed to figure out it’s no counterfeit either.
Maybe someone here has an idea? While this Problem is not something I have to fix immediately, it has surely tickled my curiosity and I would like to be able to avoid it in the future.
TL;DR: Old Office Prodesk won’t boot on random with i350T4 Network Card installed.
Have you looked into an actual bios update for the machines?
The few versions newer than the installed BIOS only listed Intel microcode updates spectre mitigation) and there were only windows .exes available.
I guess it should be possible to extract the .bin from that though and install manually though? I’ll boot one of them up tonight and see whether BIOS will let me install manually from a USB stick.
Probably will not fix the issue your having but usually the first thing I look at when having a hardware issue with cpu’s,… then again you never know.
Are the cmos batteries know good?
any obvious signs of cap’s bulging / leaking?
Power supplys known good?
