http://pcpartpicker.com/user/Roxastheman/saved/1UEU
I want to leave some room for upgrading in the future. Like adding a GPU and putting it in cross fire with the APU. But how does it look? Is it too expensive for what it is. I'd like to keep the price around where it is.
Build looks solid. very close to the build I have. same APU and MOBO. You can pick up a 6670 for around 90 on newegg, or you can hang onto some cash and upgrade your cpu gpu and mobo for around 300 later on, and your performance will be substantially better. just a thought. and yeah i needed to keep my price as low as possible for the time being.
Would a 6670 be a good GPU to put in cross fire with it though? Or should I get something better like a 7770?
you can get a better gpu than the 6670 but it wont pair to crossfire with the apu.
if he was to do that, then he may as well get a decent 4 core now and just save for the 300 graphics card later, he would get much better performance.
