How to set Nvidia GPU Power Limit (nvidia-smi)?
I am using Ubuntu and have a Gigabyte GTX 1070 G1 Gaming. In Win10 I have the power limit set +11. How can I set +11 on the power limit using nvidia-smi or something else in Ubuntu?
You’ll want to make /usr/bin/nvidia-persistenced and /usr/bin/nvidia-smi able to be run as sudo without a password.
Then to query your power limit:
sudo nvidia-smi -q -d POWER
And to set it
sudo nvidia-smi -pl (base power limit+11)
And add that to a shell script that runs at startup. (This is why we made those able to run sudo without a password)
If you have multiple GPUs:
sudo nvidia-smi -i 0 -pl (Power Limit) GPU1
sudo nvidia-smi -i 1 -pl (Power Limit) GPU2
to set a power limit of 140W use (-i 0 apples to only the 1st gpu)
sudo nvidia-smi -i 0 -pl 140
to see what your card is using run this command
nvidia-smi -q -d power
you can use anything between “Default Power Limit” and “Max Power Limit”
nvidia-smi also has a -pm option to enable persist mode
I can’t get it to open without having to open in terminal and put in the password. Also, it is part of the root.
sudo visudo
then at the very bottom, manually type in with tab spaces:
(your username)    ALL=(ALL)    NOPASSWD: /usr/bin/nvidia-persistenced
(your username)    ALL=(ALL)    NOPASSWD: /usr/bin/nvidia-smi
and save the file.
I logged to this forgotten account just to say thank you, that saved my P40 from overheating :slight_smile:
Well on Windows you can also use MSI Afterburner and set the power lmits with a GUI.
I came here to learn that you can do it also with nvidia-smi.exe. =)
Does anyone have a H200NVL pcie and a rtx6000 pro server version that they can tell me the nvidia smi power limit range (Min Power Limit) on please? Command to run is:
The PNY rtx 6000 pro’s should be 150-600 I believe:
GPU 00000000:60:00.0
    GPU Power Readings
        Average Power Draw                : 10.58 W
        Instantaneous Power Draw          : 10.58 W
        Current Power Limit               : 500.00 W
        Requested Power Limit             : 500.00 W
        Default Power Limit               : 600.00 W
        Min Power Limit                   : 150.00 W
        Max Power Limit                   : 600.00 W
    Power Samples
        Duration                          : 118.00 sec
        Number of Samples                 : 119
        Max                               : 12.24 W
        Min                               : 9.70 W
        Avg                               : 10.78 W
    GPU Memory Power Readings
        Average Power Draw                : N/A
        Instantaneous Power Draw          : N/A
    Module Power Readings
        Current Power Limit               : N/A
        Requested Power Limit             : N/A
        Default Power Limit               : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
