Hi,
In light, but not only, of amd am5 ryzen 7000 series cpu and motherboards dying/burning, is there a way to monitor the sensors on linux?
lm_sensors / sensors-detect detect nothing of use (no vsoc, volts, fans, cpu temps, mhz, …) just the following:
amdgpu-pci-1300
Adapter: PCI adapter
vddgfx: 1.07 V
vddnb: 1.24 V
edge: +64.0°C
PPT: 59.17 W
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: N/A
According to Gigabyte support, the motherboard has these sensors: IO controller: IT8689 and HW monitor controller:IT8795
I’ve tried, with no results, modprobe it87 (error… no such device) and k10temp (no more info than before).
I can see the current cpu mhz by typing “watch -n 1 sudo cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq” but looking around I couldn’t see a place where voltage/fans/etc might be stored.
A bit of a noob here, so not to comfortable in compiling/installing/etc anything that can’t easily be reverted.
motherboard: gigabyte aorus x670e master, bios f10c
cpu: ryzen 9 7900x
ram: gskill trident z5 neo
o.s.: kde neon
Thanks
