How to hookup KVM/will LVL1 KVM work for me
CompHookup
Please see the attached picture for my intended hookup for the KVM and monitors. Basically, I want the computer to never really notice that display #1 gets disconnected. Will EDID work for this?
From the description of the KVM
  • Intelligent EDID Engine for HDCP Rekeying (computers know when the port is inactive. Check out the Level1Techs repeater if you need monitor emulation)
it sounds like it will need a DP repeater/HDMI Splitter that I will need to attached between the PC and KVM for this to work.
Can anyone confirm that this will work?
Found my answer, went with another KVM as going with L1t way would have required me to buy cable + repeater which is more expensive then another brand that has it built in.
Could you share which kvm you ended up with?
