How to get into networking
I've been toying around with the idea of hosting game servers/website, however I first want to learn the basics about networking and such , what books , videos , ect would you recommend to get me started.
CompTIA Network + Do some research, I use a Microsoft book,  but TCP/IP is a backbone, doesn't matter if you're working with UNIX based platforms or Microsoft, it's mostly universally applicable.
If you want to learn how to operate the hardware and cabling (the physical side of things) nothing goes better than actually getting some switches and routers and play around with them or you could build yourself a router using pfSense/mon0wall/untangle.
The Cisco CCNA is a good starting point.
The best book for this is CCNA study Guide. I've used this book in the past and is a complete study guide to helping you get a CCNA certification if you so wish to get it. Though it is ideally best done with the physical switches and routers, it can be done within Packet Tracer (which is basically a virtual network environment)
If your on about more of Network Services (which by the sounds of it you are) with servers. Again your best to get some hardware and play around. Learn to setup DHCP servers and DNS. Setup a domain controller for your local network. Again ideally its best done with a physical box, however you can just play around with say Windows Server within virtual box. Virtualizing is a good route to begin with, because if you cock something up or something goes horrendously wrong then no damage done as it isn't a real machine.
There are lots of Microsoft guides for things that relate to their server OS's on their website. I wouldn't worry about having a valid key for if you are playing around with a virtualized box.
Seeing as you have a goal I advise you work towards that, learn how to setup a webserver in any OS (windows or linux) and then move towards securing it. Like most of computing there is a major difference between learning it and actually being able to do it and you will learn much quicker by actually doing it.
