Ok, after some experimentation, I now get discourse to speak to postfix, however it now refused to AUTH discourse and has a STARTTLS error, I’ve tried many combinations but this part looks promising. Here’s a slice of the mail.log:
Apr 16 15:01:16 fmisgaming postfix/master[5702]: daemon started – version 2.11.3, configuration /etc/postfix
Apr 16 15:06:16 fmisgaming postfix/qmgr[5704]: 8B36AADD: from=[email protected], size=36194, nrcpt=1 (queue active)
Apr 16 15:06:17 fmisgaming postfix/local[7499]: 8B36AADD: to=[email protected], relay=local, delay=366, delays=366/0.06/0/0.1, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open log file $
Apr 16 15:16:16 fmisgaming postfix/qmgr[5704]: 8B36AADD: from=[email protected], size=36194, nrcpt=1 (queue active)
Apr 16 15:16:16 fmisgaming postfix/local[9485]: 8B36AADD: to=[email protected], relay=local, delay=966, delays=966/0.04/0/0.07, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open log file$
Apr 16 15:21:16 fmisgaming postfix/qmgr[5704]: 463795D3: from=[email protected], size=36194, nrcpt=1 (queue active)
Apr 16 15:21:16 fmisgaming postfix/qmgr[5704]: 9F6922C51: from=[email protected], size=36197, nrcpt=1 (queue active)
Apr 16 15:21:16 fmisgaming postfix/local[11441]: 9F6922C51: to=[email protected], relay=local, delay=66059, delays=66059/0.02/0/0.07, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open lo$
Apr 16 15:21:16 fmisgaming postfix/local[11440]: 463795D3: to=[email protected], relay=local, delay=152462, delays=152462/0.05/0/0.1, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open lo$
Apr 16 15:35:01 fmisgaming postfix/postscreen[14116]: CONNECT from [172.17.0.2]:54532 to [192.168.2.250]:25
Apr 16 15:35:01 fmisgaming postfix/postscreen[14116]: PASS OLD [172.17.0.2]:54532
Apr 16 15:35:01 fmisgaming postfix/smtpd[14119]: connect from unknown[172.17.0.2]
Apr 16 15:35:01 fmisgaming postfix/smtpd[14119]: lost connection after AUTH from unknown[172.17.0.2]
Apr 16 15:35:01 fmisgaming postfix/smtpd[14119]: disconnect from unknown[172.17.0.2]
Apr 16 15:36:16 fmisgaming postfix/qmgr[5704]: 5C02A42F0: from=[email protected], size=36197, nrcpt=1 (queue active)
Apr 16 15:36:16 fmisgaming postfix/qmgr[5704]: 8B36AADD: from=[email protected], size=36194, nrcpt=1 (queue active)
Apr 16 15:36:16 fmisgaming postfix/local[14209]: 5C02A42F0: to=[email protected], relay=local, delay=12966, delays=12966/0.04/0/0.09, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open lo$
Apr 16 15:36:16 fmisgaming postfix/local[14210]: 8B36AADD: to=[email protected], relay=local, delay=2166, delays=2166/0.02/0/0.1, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open log fi$
Apr 16 15:38:21 fmisgaming postfix/anvil[14122]: statistics: max connection rate 1/60s for (smtpd:172.17.0.2) at Apr 16 15:35:01
Apr 16 15:38:21 fmisgaming postfix/anvil[14122]: statistics: max connection count 1 for (smtpd:172.17.0.2) at Apr 16 15:35:01
Apr 16 15:38:21 fmisgaming postfix/anvil[14122]: statistics: max cache size 1 at Apr 16 15:35:01
Apr 16 15:53:07 fmisgaming postfix/postscreen[15476]: CONNECT from [172.17.0.2]:54604 to [192.168.2.250]:25
Apr 16 15:53:07 fmisgaming postfix/postscreen[15476]: PASS OLD [172.17.0.2]:54604
Apr 16 15:53:07 fmisgaming postfix/smtpd[15477]: connect from unknown[172.17.0.2]
Apr 16 15:53:07 fmisgaming postfix/smtpd[15477]: lost connection after AUTH from unknown[172.17.0.2]
Apr 16 15:53:07 fmisgaming postfix/smtpd[15477]: disconnect from unknown[172.17.0.2]
Apr 16 15:54:43 fmisgaming postfix/master[5702]: terminating on signal 15
Apr 16 15:54:44 fmisgaming postfix/master[15726]: daemon started – version 2.11.3, configuration /etc/postfix
Apr 16 16:14:44 fmisgaming postfix/qmgr[15728]: 8B36AADD: from=[email protected], size=36194, nrcpt=1 (queue active)
Apr 16 16:14:44 fmisgaming postfix/local[19848]: 8B36AADD: to=[email protected], relay=local, delay=4474, delays=4474/0.05/0/0.07, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open log f$
Apr 16 16:15:05 fmisgaming postfix/postscreen[19939]: CONNECT from [172.17.0.2]:54825 to [192.168.2.250]:25
Apr 16 16:15:05 fmisgaming postfix/postscreen[19939]: PASS OLD [172.17.0.2]:54825
Apr 16 16:15:05 fmisgaming postfix/smtpd[19940]: connect from unknown[172.17.0.2]
Apr 16 16:15:05 fmisgaming postfix/smtpd[19940]: lost connection after STARTTLS from unknown[172.17.0.2]
Apr 16 16:15:05 fmisgaming postfix/smtpd[19940]: disconnect from unknown[172.17.0.2]
Apr 16 16:18:25 fmisgaming postfix/anvil[19942]: statistics: max connection rate 1/60s for (smtpd:172.17.0.2) at Apr 16 16:15:05
Apr 16 16:18:25 fmisgaming postfix/anvil[19942]: statistics: max connection count 1 for (smtpd:172.17.0.2) at Apr 16 16:15:05
Apr 16 16:18:25 fmisgaming postfix/anvil[19942]: statistics: max cache size 1 at Apr 16 16:15:05
Apr 16 16:29:44 fmisgaming postfix/qmgr[15728]: 463795D3: from=[email protected], size=36194, nrcpt=1 (queue active)
Apr 16 16:29:44 fmisgaming postfix/qmgr[15728]: 9F6922C51: from=[email protected], size=36197, nrcpt=1 (queue active)
Apr 16 16:29:44 fmisgaming postfix/local[22608]: 463795D3: to=[email protected], relay=local, delay=156570, delays=156570/0.05/0/0.1, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open lo$
Apr 16 16:29:44 fmisgaming postfix/local[22609]: 9F6922C51: to=[email protected], relay=local, delay=70167, delays=70166/0.03/0/0.11, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open lo$
Apr 16 16:44:44 fmisgaming postfix/qmgr[15728]: 5C02A42F0: from=[email protected], size=36197, nrcpt=1 (queue active)
Apr 16 16:44:44 fmisgaming postfix/local[26389]: 5C02A42F0: to=[email protected], relay=local, delay=17074, delays=17074/0.04/0/0.09, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open lo$
Apr 16 17:24:44 fmisgaming postfix/qmgr[15728]: 8B36AADD: from=[email protected], size=36194, nrcpt=1 (queue active)
Apr 16 17:24:44 fmisgaming postfix/local[3168]: 8B36AADD: to=[email protected], relay=local, delay=8674, delays=8674/0.06/0/0.09, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open log fi$
Apr 16 17:39:44 fmisgaming postfix/qmgr[15728]: 463795D3: from=[email protected], size=36194, nrcpt=1 (queue active)
Apr 16 17:39:44 fmisgaming postfix/qmgr[15728]: 9F6922C51: from=[email protected], size=36197, nrcpt=1 (queue active)
Apr 16 17:39:44 fmisgaming postfix/local[5430]: 463795D3: to=[email protected], relay=local, delay=160770, delays=160770/0.04/0/0.08, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open lo$
Apr 16 17:39:44 fmisgaming postfix/local[5431]: 9F6922C51: to=[email protected], relay=local, delay=74367, delays=74367/0.02/0/0.1, dsn=4.3.0, status=deferred (temporary failure. Command output: Can’t open log $
Apr 17 11:42:26 fmisgaming postfix/master[1533]: daemon started – version 2.11.3, configuration /etc/postfix
