I would like to upgrade the WiFi card in my laptop but I am unsure of where to find what ones would be compatible with Linux.
Is there a list that shows all compatible WiFi cards?
It will be for my laptop so needs to be in the M.2 form factor.
Thanks!
daniie
2
Intel Wi-Fi 6E AX210 or Intel Wi-Fi 6E AX211 should work.
The drivers should be in the kernel since 5.10.
diizzy
3
AX2X1 only works if your laptop is compatible with cnvio2
How would I find that out?
diizzy
5
What card do you have right now? If it’s not AX201 or AX211 you’re pretty much out of luck.
Also, which laptop you got, in case it has any whitelists / block lists / conflicting brands?
Legion Slim 7
5800h / RTX 3060
QHD / 165hz
16GB DDR4
diizzy
8
You can only use AX200 and AX210 (in theory), Mediatek and QCA might also be of interest. What card do you have today in it?
