How to escape array notation when passing a dictionary as a parameter in Python/Ansible?
I couldn’t find the answer to this anywhere online.
Does anyone know how to escape array notation when a dictionary key is passed as a parameter? My case is in Ansible, but I assume this is really a Python question.
For instance, this works:
selectattr('dict.key', 'defined')
But how would you use dict.key in array notation? Every combination of quotes and back slashes I’ve tried has failed. For instance, selectattr('dict["key"]', 'defined') does not work.
TIL though that you can escape a space in dot notation:
selectattr['dict.the\ key', 'defined')
That does work but looks terrible imo.
Set it as a var?
Good thought, but still doesn’t work.
quote it inside the quote, without the double quotes?
selectattr('\'dict[key]\'', 'defined')
or
selectattr('dict[\'key\']', 'defined')
If the value returned from the hashmap is a string, you can’t just pass it as an argument? (Sorry not at my workstation to test it myself).
selectattr(some_dict[“awesomeness”], ‘defined’)
I don’t want the value, I want the keys in array notation as a string.
do the var thing again..
but try the quote filter?
No dice. I’m starting to think it just isn’t supported…
Can we get an example of what you’re trying to do with code and doesn’t work?
Ansible/Yaml/python is fine, as long as it gives context ,
On macOS, I want to lookup an interface based on it’s MAC address. I don’t want to use Ansible facts for this (let’s not get into why).
On macOS, system_profiler -json SPNetworkDataType spits out a list of network interfaces. An item in the list looks like this:
      "_name" : "Belkin USB-C LAN",
      "Ethernet" : {
        "MAC Address" : "xx:xx:xx:xx:xx:xx",
        "MediaOptions" : [
        "MediaSubType" : "none"
      "hardware" : "Ethernet",
      "interface" : "en8",
      "IPv4" : {
        "ConfigMethod" : "DHCP"
      "IPv6" : {
        "ConfigMethod" : "Automatic"
      "Proxies" : {
        "ExceptionsList" : [
          "*.local",
          "169.254/16"
        "FTPPassive" : "yes"
      "spnetwork_service_order" : 3,
      "type" : "Ethernet"
I want to lookup an interface by its mac address. Test playbook (which works) looks like this:
- hosts: localhost
  gather_facts: no
  tasks:
  - shell: system_profiler -json SPNetworkDataType
    register: sysp
  - debug:
      msg: "{{  ( sysp['stdout'] | from_json )['SPNetworkDataType']
                | selectattr('Ethernet.MAC\ Address', 'defined')
                | selectattr('Ethernet.MAC\ Address', '==', 'xx:xx:xx:xx:xx:xx')
                | map(attribute='interface') }}"
But best practice is to use array notation instead of dot notation, so I’d like to use 'Ethernet["MAC Address"]' instead of 'Ethernet.MAC\ Address'.
https://docs.ansible.com/ansible/latest/reference_appendices/faq.html#ansible-allows-dot-notation-and-array-notation-for-variables-which-notation-should-i-use
maybe you need curly braces around it if you use array notation?
No, the whole thing is already in jinja brackets (I did test it though for kicks).
I have come up with a guess as to why this doesn’t work though. selectattr with array notation might result in SPNetworkDataType['Ethernet['MAC Address']'] which inherently fails, while the equivalent dot notation: SPNetworkDataType.Ethernet.MAC\ Address works simply because the syntax doesn’t wrap the keys.
I think the “correct” way to do this is probably with json_query but I was having trouble getting even a simple query to work on this for some reason…
You may be right, the docs for jinja2 only mention using dot notation for nested access …
This, using jq instead of jinja2 …
- hosts: localhost
  gather_facts: no
  tasks:
  - shell: system_profiler -json SPNetworkDataType | jq '.SPNetworkDataType| map( select (.Ethernet["MAC Address"]== "aa:7e:0e:dd:75:ee"))|map(.interface)'
    register: syspjq
  - debug:
      msg: " {{syspjq['stdout']| from_json}}"
mattiarossi@imacpro-kvm CODE % ansible-playbook a.yaml
[WARNING]: No inventory was parsed, only implicit localhost is available
[WARNING]: provided hosts list is empty, only localhost is available. Note that the implicit localhost does not match 'all'
PLAY [localhost] **************************************************************************************************************************************************
TASK [shell] ******************************************************************************************************************************************************
changed: [localhost]
TASK [debug] ******************************************************************************************************************************************************
ok: [localhost] => {
    "msg": " ['en0']"
PLAY RECAP ********************************************************************************************************************************************************
localhost                  : ok=2    changed=1    unreachable=0    failed=0    skipped=0    rescued=0    ignored=0
Nice. I am more familiar with jq than jmespath (json_query uses jmespath).
Shouldn’t:
Be:
SPNetworkDataType['Ethernet']['MAC Address']
It should. I am guessing as to why it fails.
I had luck setting my query as a var and using it that way.
I was copying the most simple example I could find in the documentation and it erroring out, so I’m sure I was doing something wrong on a really basic level. I’ll revisit it later.
There you go, jsonquery version:
- hosts: localhost
  vars:
      query: "SPNetworkDataType[?Ethernet.\"MAC Address\" && Ethernet.\"MAC Address\"=='dd:7e:ee:11:aa:84'].interface"
  gather_facts: no
  tasks:
  - shell: system_profiler -json SPNetworkDataType | jq '.SPNetworkDataType| map( select (.Ethernet["MAC Address"]== "52:7e:0e:49:75:84"))|map(.interface)'
    register: syspjq
  - debug:
    register: syspjsonq
  - debug:
      msg: " {{query}}"
  - debug:
      msg: " {{syspjsonq['stdout']| from_json| json_query(query) }}"
[WARNING]: Found variable using reserved name: query
    "msg": " ['en0']"
    "msg": " SPNetworkDataType[?Ethernet.\"MAC Address\" && Ethernet.\"MAC Address\"=='dd:7e:ee:11:aa:84'].interface"
    "msg": " ['en0']"
localhost                  : ok=5    changed=2    unreachable=0    failed=0    skipped=0    rescued=0    ignored=0
