How to correctly setup bridged network on Debian 12 for qemu?
Hello,
I am trying to setup bridged network for qemu VMs, but can’t make to work it correctly.
  • if i setup bridged network via network manager (nmtui), qemu guest VM cannot obtain an IP:
    • /etc/NetworkManager/system-connections/Wired connection 2.nmconnection:
          [connection]
          id=Wired connection 2
          uuid=<uuid>
          type=ethernet
          interface-name=enp3s0
          [ethernet]
          [ipv4]
          method=auto
          [ipv6]
          addr-gen-mode=default
          method=auto
          [proxy]
    • /etc/NetworkManager/system-connections/enp3s0.nmconnection i created via nmtui
          [connection]
          id=enp3s0
          uuid=<uuid>
          type=ethernet
          master=<uuid>
          slave-type=bridge
          [ethernet]
          [bridge-port]
  • If I setup bridged network via /etc/network/interfaces.d/ it does work in both host and guest vm (internet access work fine), but in host system:
    • Network manager DE GUI show " no connection"
      Screenshotfrom2023-10-0712-22-54.png.63514e95b8a4d73cb3295a351fecacf8
    • pc is connected to internet via bridged network br0 (and as result do not receive static IP configured for enp3s0 MAC-addresse.
    • enp3s0 interface is listed as unmanaged
    • /etc/network/interfaces.d/br0 (created via cli)
          ## DHCP ip config file for br0 ##
          auto br0
          # Bridge setup
           iface br0 inet dhcp
              bridge_ports enp3s0
How is possible to create bridged interface working in qemu guest systems and host system connection stay managed and show up in Network Manager DE GUI?
  • Start nmtui
  • delete your wired network connection
  • create network bridge
  • add networkadapter to networkbridge
  • save and quit (after that you should have a connection on your host)
  • launch virt-manager
  • select your qemunode and go to network settings
  • delete the default network
  • create network with your networkbridge and hit the start button
  • tick the auto start checkbox and hit save
  • select your networkbridge in your vms settingspage as your source
