Guru
1
- CPU: Intel I5 3570k @4.2GHz
- GPU: sapphire HD 3GB OC
- MB: AsRock Extreme4 Z77
- RAM: corsair vengeance 4*2 DDR3, 1866MHz, CL9, 1.5V
- SSD: ADATA XPG SX900 128gb
- CPU Cooler: Cooler Master Hyper 612s
so these are my specs, how much would I benefit from overclocking my RAM?
would it even be worth it, considering the time that goes into it?
I primarily play games BF3, planetside, skyrim (the more intense ones), and do some basic things on UDK (unreal dev kit).
Also, what would be the best way to overclock it? a guide would be nice...
nna2
2
no, you wont see a gain in performance from ram overclocking
If you plan on using a RamDisk, then you will. However, currently, 1866 is more than fast enough.
Sorry to highjack...but what about if his ram was 1600mhz? Is it worth it to OC up to 1866mhz? I have a similar setup and am wondering the same thing
nna2
5
not really, you wont see any big difference, and it will come with alot of headaches
you wont really see any difference
ram speed wont make any noticeable difference
