Building a TrueNAS server that will be used for iSCSI with vsphere and planning to go all NVMe flash.
Idea is to use 3x3raidz1+hot spare w/3.84TB CD6
- The SuperMicro 1114S-WN10RT is a single socket system with 2x10G copper NIC
- Using 8x32=256Gb RAM
- 2x25Gb SFP28 NIC
- This machine will probably have an external JBOD connected with SAS12 (to provide bulk storage for one of the VMs in a separate pool) unless that winds up on another box
- There are 3 (soon 4) ESXi machines connected at 2x10Gb using 13.5TB of the current flash array that is being replaced
Is a 7443P the right way to go, or is it overkill compared to the 7313P for “only” 9 drives? Other options?
